GatoGrey
Everything posted by GatoGrey
  1. GatoGrey replied to GatoGrey's topic in Roku
    Success! I went into the Roku's advanced settings and found a setting and found Control By Mobile Apps. There is a setting for Network Access which was disabled. I set it to Enabled. Control by mobile apps applies to local network as well is seems.
  2. GatoGrey replied to GatoGrey's topic in Roku
    Thank you for the quick response! The Roku is in fact at the .195 address. It is a Roku Ultra. Is the plug-in model specific or is Roku's interface standard across models? Is there anything I need to enable on the Roku for remote access?
  3. GatoGrey replied to GatoGrey's topic in Roku
    2024-02-03 08:06:45,245 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: User=0021b9026930_2 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b9026930_2 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b9026930_2 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6Njk6MzAiLCJwcm9maWxlTnVtIjoyLCJsb2dMZXZlbCI6IkVSUk9SIiwidG9rZW4iOiJHcC11UlVOUms4REhMVCVNIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjIuMTciLCJpc3lWZXJzaW9uIjoiNS44LjAiLCJlZGl0aW9uIjoiU3RhbmRhcmQifQ== 2024-02-03 08:06:45,245 MainThread udi_interface INFO __init__:<module>: Loading interface module 2024-02-03 08:06:45,286 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2024-02-03 08:06:45,794 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2024-02-03 08:06:46,012 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2024-02-03 08:06:46,013 MainThread udi_interface INFO __init__:<module>: Loading node module 2024-02-03 08:06:46,013 MainThread udi_interface INFO __init__:<module>: Loading custom module 2024-02-03 08:06:46,013 MainThread udi_interface INFO __init__:<module>: Loading isy module 2024-02-03 08:06:46,013 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2024-02-03 08:06:46,013 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.6 Starting... 2024-02-03 08:06:46,028 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.2.17 [ISY: 5.8.0, Slot: 2] 2024-02-03 08:06:46,028 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.2.67', 'netmask': '255.255.255.0', 'broadcast': '192.168.2.255'} 2024-02-03 08:06:46,029 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883 2024-02-03 08:06:46,029 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b9026930_2.cert key: 0021b9026930_2.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2024-02-03 08:06:46,037 MainThread udi_interface INFO roku:start: Starting node server 2024-02-03 08:06:46,038 MainThread udi_interface INFO roku:discover: In Discovery... 2024-02-03 08:06:46,086 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2024-02-03 08:06:46,086 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:69:30_2 - MID: 2 Result: 0 2024-02-03 08:06:46,129 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2024-02-03 08:06:46,169 MQTT udi_interface.interface INFO interface:_message: custom data response {'customparamsdoc': '<h2>Configuration</h2>\n\n<p>The only configuration options are the shortPoll and longPoll\nintervals.</p>\n\n<p>The default values attempt to balance response with network load. These can\nbe addusted to your personal preferences.</p>\n\n<p>For example, if you have a stable/unchanging setup, maybe you only want to scan for changaes once a day.</p>\n'} 2024-02-03 08:06:46,169 MQTT udi_interface.interface INFO interface:_message: Successfully set key = customparamsdoc 2024-02-03 08:06:50,267 MainThread udi_interface ERROR roku:discover: Discovery failed for http://192.168.2.195:8060/: 'data' 2024-02-03 08:08:50,288 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2024-02-03 08:08:50,288 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2024-02-03 08:08:55,289 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2024-02-03 08:08:55,289 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2024-02-03 08:09:00,292 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2024-02-03 08:09:00,292 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll
  4. GatoGrey posted a topic in Roku
    I just installed the Roku node. Looking at the log file I see this: ERROR roku:discover: Discovery failed for http://192.168.2.195:8060/: 'data' Any ideas on what to do next. Thanks!
