backinthelab
  1. It was first in the Admin Console where no city data appeared when searched, then I read this post and tried the Dashboard, to which I had the same results until I entered a valid station ID (again, I entered a random station ID that I found elsewhere on the forum). From then on, the search function operated as normal and my loacal stations appeared.
  2. Might be a bug, but I had to enter a station ID (entered a random one from another thread to start), then when I searched by city I had results. On a side note, it would be very helpful to have a sticky somewhere that highlights the procedure for doing this. I've had no prior experience with HAM stations and spent quite a bit of time googling and swearing.
  3. I'm not so lucky, even with the Dashboard. Verified firmware and UI is at 4.2.17, running OSX 10.9.4. I open the Dashboard weather settings, click "find station" (it does so correctly), click "save", then in the "Choose Area" window, the save button is greyed out. If I attempt to search via city nothing displays. Any help?
  4. I found an easy way around it, until I get another IO Linc and find time to test it. The Seco relay has to have it's own power source, so I just plugged it into an Appliance Linc and programmed it from there. A combination of buttons on a nearby Keypad Linc turns the relay on and off. The only downside I see with this configuration is when I want to integrate the lock relay into the Elk with a battery backup, but it's been working fine thus far with txt notifications and such so I'll keep it as-is for now. Thanks for your help, everyone.
  5. Sorry for the delayed reply, it's been a busy couple days. The sensor is Seco-larm, it's the same one that Smarthome sells in the kit (http://www.smarthome.com/70414/I-O-Linc ... Kit/p.aspx). I just purchased it separately since I already had a few IO Lincs laying around. It's wired to the Ground and Sense terminals and powered via it's own cord to an outlet. I will try the suggested program revisions, thank you. I've always had a difficult time comprehending correct use and placement of the "wait" commands. I'll also see if the sensitivity dial on the photosensor itself changes anything.
  6. OK, I just checked the IO Linc settings and it's on continuous latching, would this be the culprit? If so, which Momentary selection is best if I just want the trigger from an "on" command?
  7. Sure, here are the two programs. I separated them as I'm constantly disabling the voice when I'm home. If the beam remains broken (like when UPS lays a package in it's path) it keeps triggering over and over. As you can see, I've added "wait" and "stop" at random in an effort to make it wait or stop. Text Program: If Control 'My Sensors / Front Porch-Sensor' is switched On Then Send Notification to 'Text' content 'Front Porch Motion' Wait 20 seconds Else - No Actions - (To add one, press 'Action') ELK Speak Program: If Control 'My Sensors / Front Porch-Sensor' is switched On Then Set Elk Speak Phrase 'Front Door' Set Elk Speak Word 'Motion' Stop program 'Front Porch Speak' Wait 10 seconds Else - No Actions - (To add one, press 'Action') Ahhh, just thought of something, could it have anything to do with the settings on the IO LInc?
  8. A quick question, as I'm too lazy to sift through the search results.... I have a photosensor going across my front porch (wired to an IO Linc) and one program set up to have the ELK speak "Front Porch Motion" and another to send me a text message whenever the beam is broken. My issue is that if someone stands in the path of the sensor, my phone blows up with continual texts and the Elk just keeps repeating over an over. I've tried the "wait" command to no avail and I'm unsure if I should use a "stop" or not. I'd like to have a 10-20 second pause before it acts again. I'm sure this is easier than I'm making it, can anyone help me out?
  9. backinthelab replied to tome's topic in ISY994
    Thank you for clarifying and for keeping our privacy concerns as a priority. I had figured that the ISY wouldn't be accessible to outside sources without our consent, but the name "AutoDR" made it sound like it was defaulted into doing so. Thanks again!
  10. backinthelab replied to tome's topic in ISY994
    I had wondered what the AutoDR scene was for, now that I know, I would kindly ask to give us the option to remove it. There is a HUGE battle here in Michigan over government-mandated SMARTmeters and I do not wish to have any technology in my home that would appear as if I support these measures, especially given the latest revelations of privacy violations by the US government.
  11. I understand that it's not a typical request, but the way I see it (Insteon gurus please correct me if I'm wrong), is that it's similar to the function of a garage door opener. You have a key fob transmitter that activates a receiver that, in turn, switches a relay. I can probably figure out the wiring if the lock, it's just that the IOLinc always seems to rack my brain in its wiring and operation.
  12. I'm in the process of building a secured room of sorts and have been researching electromagnetic locks as one of the means. Most "kits" being sold come with an RF receiver and transmitter, typically Seco-Larm. I'm curious to know if the IO Linc could integrate into this and, if so, how would I go about wiring it? My intent would be to disable the lock via either Mobilinc or a series of KPL buttons. I would assume that it would be along the same lines as the wiring to my garage door opener, however, if anyone has some (detailed) insight it would be appreciated. Wiring these kinds of things isn't one of my strong suits! PS I've already looked at Morning Industries, however, this will be a pocket door so a normal deadbolt won't work.
  13. Lee, thanks for the reply. I wasn't sure if A was even possible given my limited knowledge about electrical current. My thinking was that if the Inlinelinc could sense the load going to the light when it turns on, and did not actually sense the motion detector or control the power to the light, that somehow it might work. Looks like a trip to Home Depot is on my schedule for tomorrow! Thanks for your help, do you recommend any certain brand/model of sensor that I should buy to replace the Dual Bright?
  14. After the electrician installed a couple of motion lights, I found out the bad news regarding the Dual Bright sensors not being compatible with the Inlinelinc. I'm wondering if there is a way around my dilemma by either: A) wiring the Inlinelinc to only sense that the motion light has been switched on, sending only the status update to the ISY with no load. (I have no need for the Inlinelinc to switch the light on, anyway.) purchasing a replacement sensor that is compatible and replacing the Dual Bright season on the fixture I'd obviously prefer option A, if it's possible, I just don't want to have to replace the whole fixture. Thoughts?
