AZGuy
Everything posted by AZGuy
  1. To help manage heating costs, this program will allow for a slight increase in temperature and then changes the set-point back down. The 'heat' mode is needed to prevent the set-point from changing if the thermostat is in cooling mode or off. MaxTemp TV Room - [ID 0004][Parent 0001] If 'TV Room T Stat - Main' Temperature >= 74.0° And 'TV Room T Stat - Main' Mode is Heat Then Set 'TV Room T Stat - Main' Heat Setpoint 72° Else - No Actions - (To add one, press 'Action')
  2. I found this program for updating thermostat temperatures without the 2-3 degree change. The 20 minute update seems to work fine for my needs. T Stat Update - [ID 0002][Parent 0001] If Time is 10:05:00PM Then Repeat Every 20 minutes Set 'TV Room T Stat - Main' Query Wait 2 minutes Set 'Master T Stat - Main' Query Wait 2 minutes Set 'RearBR T Stat - Main' Query Else - No Actions - (To add one, press 'Action')
