EngMarc
Everything posted by EngMarc
  1. yeah, I did use the spare 100uF 50v caps in C7 and C13. I didn’t want to wait on the other ones I ordered. they are there and working so far.
  2. So, took out C1 and checked it against the new one (bought two) and the forward and reverse resistance was quite different. So, I put in the 2nd C1 which is a 400v 10 uF electrolytic capacitor. Replaced the 2W resistor that blew. Checked resistance and polarity and then put it to the 110v test. Volia! Everything seems fine now and the green light on the side is light up. I pressed the button and it beeps in sync mode. This is a v2.0 PLM so it has some changes but not all the 2.5 changes. Evidently the C1 did short in reverse. I checked all the subsequent capacitors I had replaced and they are correctly polarized. So now I have a spare PLM! A BIG BIG shout out to both Brian and Teken for their great support, feedback and knowledge. On another note, I have lots of spare components so if anyone needs some capacitors or 2W resistors let me know. I’ll happily send some. Marc
  3. So I went through D1-D4 and they seem to test fine with 0.5 positive and 0 negative direction. D10 was also good. when I put full 110v on the inputs it shorted the same 2W resistor. This is new after my recapping so suspecting my work. at first, I wasn’t aware a cap had a plus and neg post. So it is very possible C1 or C3 are in opposite as designed. Would that cause a short behavior? i think I just found my answer online which states electrolytic capacitors will short if connected in wrong polarity. I'm going to remove C1 as when I checked it, the black negative stripe is on the (+) side which means it is reversed polarity. C3 and later were when I realized there was a polarity to these caps and they were installed correctly. I have a spare C1 (ordered 2 or 4 of everything since the postage was more than the parts). I’m going to see if I can tell if the current C1 is completely gone or if it just shorts - ideas?
  4. Thank you, sounds like a plan. I’ll work on it in a bit. also, I noticed yesterday when soldering in the 2W resistor that one leg is VERY close to the head of D3. From the schematic it appears this is ok as it appears the 2W 27 ohm resistor is indeed connected to D3 input. Can you verify for me (four eyes are always better than two )?
  5. Brian and others, I soldered in the 2W resistor and connect a low ameperage 110v feed, it seemed to have a possible short but I can’t find it. Not sure if the initial charge of the new caps was large. the 2W resistor is still intact but seemed odd. I’m not too good at low level debugging of the circuit but will try some later on. I did use an isolated 110v power supply and ran it through a mAmp feed. I’ll try the direct connect to the isolated power supply and go through the voltages at the locations of interest to see what I find. Ideas?
  6. yeah, I’ve got both in my possession now. the 2W is almost exactly the same size as the old PLM has installed. I’ll play around with debugging that unit and the circuit with the replaced caps.
  7. Brian, actually Indigo has a link update function which reads the new PLM and then will send all insteon devices a refresh link update and synchronize it with the PLM. I ran this yesterday and it ran like a charm. The new PLM is up and running nicely. I did notice that when the old PLM was running near the end of its life, there was some very odd behavior in the insteon devices (flashing lights on same device with ceiling fan turned on, etc.). This had completely gone away. At the time, I thought this was an insteon fan module going bad. Turns out, it seem that the PLM was going bad. Today, I on a whim found 2W and 5W resistors on Amazon. I ordered them just to have them and start some testing. The 2W is almost exactly the same size as the old PLM resistor so it is likely a 2W as theorized.
  8. Brian, I use my 2413U with a usb cable to my mac which runs Indigo. My whole house automation platform.
  9. So the new 2413U arrived and is a rev 2.5 I’ve attache’d some photos inside and as can be seen it has the two larger caps laying on their side as has been posted here for other newer revisions.
  10. Thanks for the page reference. My 2413U looks kind of like the v1.7 shown in the photo but not quite exactly the same. I’ll see what the new one looks like when I receive it tomorrow and post a pic. I ordered it from Amazon which appears to come from Smarthome. I saw a ton of them on ebay but didn’t want to go down that path since I’m going to be repairing the old one I have - I wanted one that definitely worked.
  11. yeah, I’m using the 2413 USB version and not the serial version (2413U vs 2413S). Not sure the exact difference as I don’t have a 2413S to compare to but the daughter board is likely the difference rather than the parent board.
  12. so for now, going to purchase a new 2413U since it’s mission critical and waiting 2-3 weeks for these resistors is more than I want to put up with. I’ll continue to work on repairing this older version. I did open up an insteon 2450 serial interface to see what resistors were in it. they appear to be red-brown-black-gold and about the same size 2W or so. I don’t see any part numbers on them so can’t tell where they came from.
  13. was told the 1W and 2W resistors are on back order so won’t get my shipment until around end of July or early August. More to follow…..
  14. Just ordered these: Qty. Stock# Mfr. Part # Cust. Part # Price (USD) Total (USD) 4 70723850 1W027 $0.140 $0.56 RESISTOR 1 WATT METAL OXIDE FILM FLAMEPROOF 27 OHM 2% AXIAL LEAD 4 70725136 F2W027 $0.400 $1.60 RESISTOR; FUSIBLE 2W 27 OHM 5% 4 70112166 107CKH050M $0.150 $0.60 Capacitor, Cap 100 uF, Tol 20%, Vol-Rtg 50 VDC, Radial, 8x11.5, ESR 1.658 Ohms
  15. ok, let me see if I can order/get an F2W027 (2w 27ohm 300v). Thanks for the quick response. I’m trying to resurect my PLM. Last resort is to buy a newer version but I really want to resurect it instead
  16. yeah, the one on the left is the Amazon resistor. I’m going to search for a 2W or something resistor. Ideas on choices? I found these but have no idea which is best or if I should go to a higher wattage since it fried (maybe a short or maybe not)? https://www.alliedelec.com/view/search/?keyword=27+ohm+2W+resistor Although reading some of the stuff on cermaic resistors seems contrary to the PLM (not tolerant of surges).
  17. So, received my resistors today from Amazon and they don’t look anything like the one I removed. The one I removed is at least 200 times larger. Any ideas on why the size difference? Here’s a photo.
  18. sorry for the confusion, those voltages were from the other guys post (I should have removed the ‘I’). I was going to use them as a gauge for my testing. As for the daughter board, yes there is a USB daughter board on this 2413. I can connect it up when testing if that makes more sense. I won’t have it connected to a USB though if there’s a difference I could probably negotiate that setup. My home automation system isn’t anywhere near my test bench though ;).
  19. Ok, will let you know once they arrive and I start testing. Any other values for test points that you have would be helpful. I have the ones from page 282 post: For reference the voltages I measured across the new capacitors are as follows: C3 167VDC C7 21.1VDC C13 21.1VDC C8 4.9VDC C11 4.4VDC
  20. yeah, I wasn’t sure what wattage they needed to be but was ordering some other stuff and thought for $5 free shipping why not try them. Let me know if you have any idea on the wattage for the 27 ohm resistor?
  21. Here’s pics of my board top and bottom with the R1 resistor removed. I checked resistance on most of the resistors and across the capacitors and couldn’t find anything that stuck out. The existing 27 ohm resistor that is original reads about the same as the two pin holes for the removed resistor. So, not sure if it was just a voltage spike that fried the resistor or what? I’ve ordered an isolated 110v power supply so I can futher debug the circuit. I’m going to put in a 27 ohm resistor (probably not the best but wasn’t sure what to replace it with right now) and test out the circuit. I know bad but found some 27 ohm 5% resistors on Amazon so took the plunge to get something to debug with (https://www.amazon.com/gp/product/B0185FERU0/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1). If you see something you think from Mouser or Digikey let me know.
  22. I ordered from danu1964’s list so when I received them and went to replace them I found some differences. The version I have has two Fujicon 100uF 35v and I had ordered the EKY-500ETD100ME11D 10uF 50v so put those in. They were higher voltage but lower capacitance than the FUJICON. I haven’t had time to check the actual datasheets yet. > What do you think would be a good replacement for the FUJICON 100uF 35v capacitor in the stock 2413x board? As for the resistor, it looks like there are two and on the board itself it is labeled ‘R1’ but I don’t see that on the schematic from pg 282. On the schematic, it appears to be labeled R2 or R10 (not sure which one is which on the board but they are next to each other). I took a really close look at the board and there is a possible sloppy solder on C11 near R12 (very close base on C11 to R12). But also see what looks like some brown burn area near C6, R5, D6, R21. I’m going to go through these to check values and see if there’s a short. > I’m trying to figure out what a good R2 27 ohm resistor would be. I’ve looked on Mouser but there’s too many choices. Ideas?
  23. What should we use for the C7/C13 change out (has Fujicon 100uF 35v in there)? Also, I tried using the EKY 10uF 50v to replace the FUJICON 100uF 35v. At first it lit up the side light but then there was a flash and it went dead. On dissembly, the below pic shows the resistors which straddle the black 110v lead. I can’t quite tell if its Red-Violet-Black-Gold or not as it burned the bands. The other resistor next to it is Red-Violet-Black-Gold. Does anyone have any experience with these and ideas why one shorted? I’m sniffing around the circuit but haven’t found anything off yet. Without a circuit diagram it’s kind of just hunt and peck so to speak.
