JHyder
  1. If anyone has suggestions or a solution that would be much appreciated. In a nutshell the issue is that the Alexa app will not re-discover the Insteon devices in my the home network. After the ISY was restored from being offline and also from the Portal account not being active, the Alexa app listed all Insteon devices but said they were unresponsive. I then removed them from Alexa with the hope of adding them back but Alexa evidently doesn’t think they are new and so won’t discover them. As a result, we’re unable to control any Insteon devices through Alexa now. Any thoughts on how to reset Alexa to discover the existing devices? I have unlinked ISY Optimized for Smart Home V3 and relinked a couple of times now. Deleted and reinstalled the Amazon Alexa app… All met the same results. Would creating a new account on the Alexa app help? I don’t want to compound the issue by having duplicate accounts but willing to try most anything. I tried to add devices manually and found it odd that Insteon was not a listed device manufacturer (example for switches) so that effort met a brick wall as well.
  2. It's not worth the trouble I suppose. I have read the motion sensors have increased programming options with v5 and was hoping for something similar with the 2477S. Thanks all.
  3. JHyder joined the community
  4. I don’t readily see this capability but thought I’d ask. Is it programmatically possible to control the On/Off LED of the 2477S SwitchLinc? Id like to use the LED as an indicator for something else and would like to be able to set the LED to the upper (ON) position or the lower (Off) position via a program without turning the switch itself on or off. FYI: The switch is part of a 3 switch cluster next to the door which goes from the kitchen area to the garage. This particular switch controls a light that is seldom used and I’d like to program the LED to reflect the status of the garage door (eg, LED top if garage is open, bottom if closed). I just don’t see a way to control the LED status via a program. That likely means there is no way to do this but I thought I’d check here. I’m running v4.80.
