Scud
Everything posted by Scud
  1. What mode do you have your Relay in? My understanding is if you have Trigger Reverse selected it will be un-selected after a power outage or reboot.
  2. Set it up for my gate and 2 garage doors and it is working Great! Thanks again for the help on this. -Mike
  3. Thanks for all the help. @tmorse305 quick test this morning and this seems to be doing the trick. Thanks again, Mike
  4. Oberkc thanks s for the info. I am now getting a little confused. The THEN path on both Open and Close program's are the same. Both set the relay to on.
  5. The status in the ISY is correct for the sensor but the status in the Program Summary seems to not be correct ever. Going crazy over this.Should be very simple.
  6. @slimypizza I am trying to duplicate your setup to Open and Close garage door with Alexa. I have the following programs and created a routine in Alexa app , one for Open and one for Close. What happens if I say Alexa, Open Small Garage it will open the door. If the door is already open and I Say Alexa, Open the Small Garage it will close it. Doesn't seem to look at the "if" on the program for the sensor status. Something I am missing? Small_Garage_Open - [ID 0011][Parent 0013][Not Enabled] If 'Garage_Gate / SmallGarage' Status is Off Then Set 'Garage_Gate / SmallGarage / GarageSmallRelay' On Else - No Actions - (To add one, press 'Action') Sensor On = Open Small_Garage_Close - [ID 0012][Parent 0013][Not Enabled] If 'Garage_Gate / SmallGarage' Status is On Then Set 'Garage_Gate / SmallGarage / GarageSmallRelay' On Else - No Actions - (To add one, press 'Action') Small_Garage_Relay_Off - [ID 000C][Parent 0013] If 'Garage_Gate / SmallGarage / GarageSmallRelay' Status is On Then Wait 16 seconds Set 'Garage_Gate / SmallGarage / GarageSmallRelay' Off Else - No Actions - (To add one, press 'Action') Thanks, Mike
