lafleur
Everything posted by lafleur
  1. Anyone have a copy of the Rainforest EAGLE Socket API Manual, it's no longer on their web site and I'm in need of a copy. Thanks Tom ... @ ... Lafleur ... U.S.
  2. In general, a motion sensor is located in a remote place that is not within easy access. Many times one need a ladder for access. But when I set the JP5 jumper, I should be able to program and operate them from the ISY... but NO, I must get the unit, bring it to the PC and press the button on it, do the programming and then return the unit to its place of operation, test it and maybe do it all over again... You should explain this to the manufacture, that when the JP5 jumper is installed, the ISY should be able to program or reload the device at will, without the required removal and pressing of the stupid button... They need a firmware upgrade to make this device work correctly and to make a device that will work easily with automations system like the ISY. Thanks...
  3. lafleur posted a topic in ISY994
    I have a program that is not working as I expected... if status 'motion sensor' is on and from sunset to sunrise (next day) then set 'light ' on wait 4 min set light off the program work as expected to turn on the light, but it works day or night... ie: the from sunset to sunrise (next day) is not working??? program enclosed... tom @ lafleur.us ver 3.1.11
  4. lafleur posted a topic in ISY994
    What will this realy do: will it repeat this sequence 4 times? 4 times 5min = 20 min thanks.. If From Sunrise + 20 minutes For 20 minutes Then Repeat Every 5 minutes Set 'Front Door Light' Off Set 'Back Ext Trim Lights' Off Else - No Actions - (To add one, press 'Action') This will turn OFF all outside security lights
  5. lafleur posted a topic in ISY994
    What I am trying to do is, setup 8 KPL with button H setup as Flood, so if you press it, it will turn on all of the floods... In 4 of the cases, KPL-A also control the load. If I press A, it will turn on the load, if I press H it will turn on all of the Loads except for the one on the local KPL... I did try what you suggested below, I added all of the KPL-H 1st, then added the loads, making sure that the KPL-A were all last... But it still did not work?? any ideas?? ------------------------------------------------------ On the other hand, if both H and A are both in the same scene, then please make sure that H (or any other sub button for that matter) is added to the scene before A. i.e. you have to make sure A (or the load button) is the LAST button/node to be added to a scene. This is a KPL limitation which we cannot do anything about. With kind regards, UDI Tech Support More information: http://forum.universal-devices.com Sent by: Michel Kohanim
  6. We need NTP time support in the ISY, so that the ISY always has the correct time... You could select manual or automatic.. manual would be what you have today.. if automatic, let the user set the NTP name or ip address... this is what is done in most routers and computers today. No need for a default list. see below for current method of setting POOL servers... http://support.ntp.org/bin/view/Servers/NTPPoolServers
