DJonas
  1. I started many years ago with an ISY and upgraded the system a few years ago to an Eisy. These primarily control Insteon devices but have grown over the years to include a few Hue devices, some Yolink. It has all worked pretty well. Except integration of voice control with Aleza. While I have been able to make Alexa voice control work, it is inconsistent. Alexa loses the connection. Worst of all, Alexa, hands down, has the most frustrating and unintuitive interface I have ever experience. They should be ashamed to produce it. I am looking for a good approach to create some simple voice controls that will work with the Eisy. Basically, I am controlling some office and bedroom lights. All are Insteon based and work within the UD interface. Two of the bedroom lamps are Phillips Hue bulbs. I have the Hue add-in for Eisy but that has also stopped working. I can control the Hue lights directly with the Hue App. I'm wondering which way to go, of give up. Apple Homekit with hub? Home Assistant? Or something else. Whatever it is, the interface needs to be user friendly. I am more than happy to spend a few bucks to throw the Alexa product in the trash., Any Suggestions?
  2. Dennis, Thanks. It isn't that I am new to the Eisy, I set most things up many years ago when I had the original Isy, The problem is that I rarely need to access to modify anything and I am old and forget. I think I have it back on track.
  3. Thanks, Confusion gone. I figured out (fount) the portal user name and password. Why the change?
  4. I am confused. Maybe I don't understand what the "portal" is. I thought that was where I had additional add-ons setup and I've navigated to that information from within the UD program launched with the icon. I am not aware of a separate username and password for the "portal". So I guess the question is how do I reset my password in the "portal".
  5. I selected update, which it did, and now I can't log into the Eisy from IoX launcher. It does not seem to know my username or password (probably password) any more. I can log into it using the user name and password with eisy.local I cleared the JAVA cache and all programs already. Did not help. How do I fix this?
  6. Yes, it is a sectional garage door and I have it mounted to the back of the top panel. The door is currently closed and it is reporting nothing. Neither open or closed. Battery is 27%, which is surprising as the sensor is only 30 days new.
  7. I am trying out a Zooz tilt sensor to determine if a garage door is open or not. It appears to be working part of the time. In particular, it works when the door is open or closed for a longer period of time. But if the door is opened (it reports properly) and then shut within a few minutes, the sensor continues to show open. I think I have the settings correct, but who knows. I find the Zooz documentation, particularly as it relates to use within the Eisy rather lacking.
  8. DJonas replied to DJonas's topic in eisy
    Looks like that is the problem. I understand the issue but seems like the email provider could allow specified exceptions. A text is usually a better notification process than email.
  9. DJonas replied to DJonas's topic in eisy
    That got me most of the way there. Was it the time out change 1000-8000 or the FROM? I thought the FROM was optional. The email notification worked. I included phone#@vtext.com and received a permanent error message in my email for that. What works for text message?
  10. DJonas replied to DJonas's topic in eisy
    I've done all of that, multiple times. Using both Default checked and inputting the email settings. When testing, I get an SMTP error code 1 or 18 depending on the settings.
  11. DJonas replied to DJonas's topic in eisy
    I have Notifications Plug-in. I get notifications on UD Mobile. But how do I send a message (email and/or text) from the UDI interface? I don't see anywhere where I can select use Notifications.
  12. DJonas posted a topic in eisy
    Converted over to the Eisy. My notification email and text are gone. I use an Exchange account, a comcast email account and xFinity for phone. I can't figure out how to get any of it to test working. I tried the comcast with the following settings: smtp.comcast.net, MyUserName, MyPassword, Ports 995, 587, 465 I think. TLS on and off. Xfinity is not listed in the text message list. Tried the Comcast...nothing. Not sure what to do next.
  13. Nice of them to give one so much time. Sounds like it is going to have to go up and down a few times to get things adjusted. I was thinking of putting a temp sensor in my attic. If I have to retrieve it to reset something, that now seems like a bad plan.
  14. Which brings up the question, exactly what is linking mode? Do I need to take it down, remove the back and use that back button? If so, pretty poor design.
  15. Still figuring it out. Zooz says its range is 30 feet. I'm seeing motion at closer to 40 feet. That will be a problem for me if I can't adjust the angle or sensitivity enough to tone it down. I have it pointed all the way down. Might have to build a wedge mount. I wish it had a range adjustment. Tried setting some parameters but can't tell if they are getting reset. I have the Event Viewer on and when I query a parameter, I see the get, but not a result. Same with sending a parameter. See a send, but not sure it is taking it. I like the design and quality. Not many outdoor motion detectors that are quality. I tried the Insteon, which is probably indoors, but the mounting on that thing looks like it was designed by a five-year-old.
