chevykid
  1. chevykid replied to JGraham's topic in UD Portal
    So, do we get an answer of what happened?
  2. So this is what I had to do, I had to 'run' 2 times with a "Wait 1 minutes" in between, for it to work, it was intermittent otherwise. If Time is Sunset - 1 hour and 15 minutes Then Set 'BEDRM LAMP' 20% Run Program 'Set_BDRM_BACK12' (If) Wait 1 minutes Run Program 'Set_BDRM_BACK12' (If) Wait 30 minutes Set 'BDRM.Back Porch Light' On Thanks!
  3. so when you disable a program it's not totally disabled. thanks i'll see if it works today.
  4. chevykid posted a topic in ISY994
    here is what i got: If Time is Sunset - 1 hour and 15 minutes Then Set 'BEDRM LAMP' 20% Set 'BDRM BACK' 12% Wait 30 minutes Set 'BDRM.Back Porch Light' On this program has been running great, what I would like to add is if 'BDRM BACK' is already on, to leave it at the present level and not change it to the 12% setting. thanks!
