Chuck
  1. Michel, I am hoping to get this resolved. You mentioned getting in contact with your tech support team. Please have them contact me. Thanks, Chuck chuck@professionalavi.com 319-430-2482
  2. The PLM light does not blink without traffic.
  3. Michel, Now the new device is showing the same symtoms! The icon next to it in the admin console is green and all associated scenes show the ramp rate as 9m. The first attempt at changing the ramp rate within a scene results in: [-110022] Couldn't open file [/CONF.ADR.CFG] [-110022] Couldn't open file [/CONF.FYP.CFG] Subsequent tries result in "Request Failed". Please help. Thanks.
  4. Yes, I replaced it. I was initially planning on selling Insteon (I own an electronics integration business), so I have some in stock.
  5. Michel, I replaced the device and had the same errors, even when powered directly into the PLM. I removed the device and added it as a new device and manually added it into all the scenes and programs and that worked. A pain, but it worked. I'm not sure why. Chuck
  6. (That's supposed to be "v.28", not a smiley face in that last post)
  7. Michel, I plugged a LampLinc (2456D3 v.28) directly into the PLM and could succesfully change it's default settings and settings within scenes. I have not moved the ISY/PLM and have not added anything. Thanks, Chuck
  8. After pressing "ALL OFF", I still get "Request Failed" when trying to adjust the device settings within any scene. I do not use any SignalLink RFs or Access Points. The system has been working for over a year up to this point. Thanks, Chuck
  9. I'm using v.2.7.14. I tried to upgrade to 15 and get, "Upgrade failed:invalid or incompatible upgrade file". The problem exists with the device on or off.
  10. it's a 2476D v.27. Does this mean it's bad?
  11. I have had a pretty reliable setup until a few days ago when I noticed a switchlinc dimmer not responding to scenes. I also noticed in the admin console it showed up with a different green icon next to it. The icon changed back to normal when I did a query on the device today. The device level and ramp rates within scenes show as comepletely different settings than it was originally set for. When I 1st open the admin console and try to correct the level or ramp rate for this device inside a scene, I get: [-110022] Couldn't open file [/CONF.ADR.CFG] [-110022] Couldn't open file [/CONF.FYP.CFG] And upon further attempts I get, "Request Failed". I can succesfully query the device and change it's default levels. Please help. Chuck
  12. I just was checking my devices and discovered they all show "0%" for the On Level and "9.0 Min" for the Ramp Rate. The correct values show up if I query each device. Is this a known problem? Is it a good ideo to do a complete system reset/restore from time to time? My main system consists of a 99i v.2.6.7 and about 15 insteon devices. What would be the correct procedure and order? Thanks. Chuck
  13. I did observe when I pressed All On or All Off from the Admin Console for the system in the garage it turned on and off a nearby 2476D, which was never linked to this PLM. I tried adding then removing the 2476D, but it still is controlled by these All On and All Off buttons. Is this normal? The PLM was new and I restored it before adding any devices (to "clean" it). The ISY-26 was previously used with this 2476D and other devices, but I did a Factory Reset before starting. There shouldn't be any traffic from the garage - nobody's in there. Any programs and scenes are only for those devices connected to the test strip in the garage. If your repeaters (any Insteon device) are distant this could create a problem (or at least use a Insteon HOP).
  14. Thanks for your input and work Mike. The conditional folders were for Sunset to Sunrise (next day) and another for Sunrise to Sunset (same day). This appeared to work most of the time. I did remove the programs from these folders and things seem to be working better. Backing up...I think the source of most of my problems was a 2nd PLM and ISY-26 I've been configuring in my garage (for a customer). Although I had issues before (Hopefully because of this conditional folder bug), they became much worse after I started this second ISY project. I unplugged the 2nd PLM and ISY and the LED status programs run without a problem (so far). Which brings me to my next question: I am planning on configuring the ISY-26 to work in conjunction with mControl. This means I'll need a PLC plugged into the same outlet as the PLM. Is this going to cause similar communication problems? Thanks, Chuck
  15. Yes, I meant SignaLincs. I thought maybe this would help with the issues. The only folder condition is the time of day and the status of the folder condition is True. This is a LampLinc. I have removed this in the past remembering something about them not always returning status properly. Do you know what the actual limitations are with LampLincs in this regards? All Off from the main console does work. I substituted the SwitchLinc linked to the LampLinc and it is working (for now). I will keep you posted. Thanks!
