MBell
  1. What I meant was - most developers are not out there on their own. The product owners should demand a first run at any updates that may affect their product. Most developers place their update in a repository so the rest of the development team can test against their dependncies. I get all of the love for this team, me included, I just think you all could be much better if tighter processes were put into place. Since the launch of PG3 I have witnessed countless issues, not only with the node development but with UDI as well. Im sure I will receive hate messages for this, but why can't a user ask the node developers and UDI to do better? Cheers,
  2. What a joke. It appears you all need to communicate better. These kind of issues are so annoying. One person announces new version, only to tell people 4 hours later "oh please wait until Monday" Well all of the users that updated OH WELL.
  3. This is why cloud dependent IOT has always been my last choice. I want full control and ownership of all my IOT. If it is cloud dependent, do you really own the device?
  4. I have request for the app notifications specifically the after the push notification. If it could be customized so that you could chose to just get the push notification without storing a notification in the notifications. I have many use case scenarios where I only want a push notification without it showing up in the notifications within the app. That way I could have a push notification without having a string of history notifications. See photo example: I only want a push notification and not these shown in picture. thanks
  5. You could try a local control. Although you would need one for each control. https://paulwieland.github.io/ratgdo/
  6. MBell changed their profile photo
  7. Followed these suggestions and all nodes are connected and working. Did return some errors after re-installing aioquic? Do let us know if you all need anymore logs? Thanks,
  8. Is there any chance you can be more detailed about how to perform this downgrade? I am familiar with ssh but have no idea how to add that pkg to my eisy? thank you, BTW, I opened a ticket with all of the logs you ask for.
  9. I have ran into the same issue. None of my nodes will connect. They all show disconnected after updating from 3.2.2 to 3.2.3 I have confirmed PG3X is 3.2.3 IOX 5.6.4 If I go to UD mobile app/admin/configure portals, I get the following error message: "no LOCAL IP ADDRESS is set for the system. System name Eisy" I have confirmed the IOX is set to http://127.0.0.1:8080 Wonder what changed in 3.2.3 that was not an issue with 3.2.2? Anyone have any suggestions before I open a ticket?
  10. Well that’s disappointing for sure. Not sure aquara devices are proprietary as stated? I have a HA yellow with built in zigbee coordinator and all aquara devices work without an aquara hub with no issue on HA?
  11. Updated pkgs through admin console. Came back 30 minutes later said system needs to reboot. Used reboot button on admin console, console closed out, waited a few and console still shows system needs to reboot. Tried this 3 times no luck. Had to unplug eisy in order to get it the update to complete. Reinstalled all node servers. Aside from what was mentioned above, all seems good.
  12. Well that’s disappointing for sure. Not sure aquara devices are proprietary as stated? I have a HA yellow with built in zigbee coordinator and all aquara devices work without an aquara hub with no issue on HA?
  13. Port 3001 needs to point to the LAN IP of the rachio.
  14. Port 3001 should be pointed to the IP address of the Rachio. Find your WAN IP address and Use port checker and see if it returns as open. Also it takes a while for the Rachio data to show up.
  15. Aquara SJCGQ11LM https://www.aqara.com/en/water_sensor.html Leak sensor, battery data.
  16. Aquara TVOC sensor AAQS-S01 https://www.aqara.com/en/product/tvoc-air-quality-monitor Temp, Humidity, TVOC, and battery data.
