Dave H
  1. 4 tap test plus lilyyoyo1's suggestion carry the day. Thanks everyone! -dave
  2. Thanks all-- 1. firmware and UI version 4.9 2. not sure about phase, but I have plugged a repeater into the same branch circuit and I see that communications are very reliable. 3. Did a factory reset of outdoor module and another PLM restore Same error message! -dave
  3. Neophyte. First use of new 994. Half dozen controllers, a dozen lights. Trying to communicate with an outdoor on/off unit, consistently getting this error: "The following devices could not be added: 22.80.75 (2634-222) On/Off Outdoor Module V.00 device is an old PLM, do Restore modem and try again." I've done the restore modem, and tried manually and automatically to find this device. When I do it manually I get the above error, when I try to do it automatically, the device is not found even though the controller it is linked to is found. controller and device work as programmed. help. -dave :
  4. yes, i see that. i was looking for mini-remotes. it took a couple of tries (i think the miniremote was timing out), but it is now added along with its scenes. thanks!
  5. as best as I can tell. I did not see any specific to the mini-remotes. They are battery powered...do perhaps the process is different? -dave
  6. Dave H joined the community
  7. New user...successfully linked a dozen switches and lights....but mini-remote 2432-2 is not recognized. ISY is reporting "unable to find insteon engine" (or something similar). thanks!
