abrayshaw
  1. Geddy - Thanks again for the feedback. I neglected to include that I deleted 2 files found in the c:\Users\[Username]\AppData\Local\Temp folder, but that's something I had already done yesterday without success. So, maybe it was the SD card. As for firewall issue -- I had turned the firewall off while troubleshooting, but can you tell me if there are any files/folders that I can add to the fw's exceptions list to avoid possible interference in the future? Thanks again! I'm learning a little more each time I have trouble, thanks to folks like you.
  2. I finally got it working, but don't ask me how..... This morning, I followed Techman's advice, and removed the micro SD card, cleaned the contacts, and reinserted it. While i was at it, I completely removed Java and reinstalled it. Then I ran start.jlnp, the icon was back on my desktop, finder loaded, I clicked on the ISY's displayed line, chose LAN and it started up like it used to. Whew! The only thing I did that I hadn't done yesterday was to clean the msd card. So, still can't be sure that was the solution. The last time this happened (couple months ago), I did get it solved but there was no clear reason as to how I got there. But, I won't argue with success. BTW, I had tried choosing the cloud option in the finder (IndyMike's idea) and while that displayed an interface, the contents were incomplete and I couldn't edit programs. So, not sure what that option's even good for. Still much to learn. Thanks for all the help.
  3. Yes, I've rebooted the ISY several times. I've noticed that a failed attempt to access the admin console (as I described in an earlier post) sometime requires me to reboot to get it working again. For instance, I notice the ISY won't control zwave devices, but will still control X-10 devices. Rebooting the ISY resolves this, although I still can't get into the interface. I will try leaning the SD card -- nothing else seems to work!
  4. I've attached a screenshot of my finder window. As you an see, it's listed as the ISY's IP address, and the address is reserved in the router as a static address. So, I think I've done all that's been suggested, and still no luck. This was all working a few weeks ago, then all of the sudden, it's not. Very frustrating, to say the least. I've resisted upgrading to the eisy, not only because of the cost, but because the ISY does all I need it to do --control z-wave and x-10 light switches. Is there something about the eisy that makes it less prone to the problem I've been seeing? Thanks again
  5. Geddy - I followed your instructions - found 2 files from the list on the wiki. Deleted them, cleared the Java cache, disabled both my firewall and AV software, rebooted. Still no luck. I have another Windows computer - I'm about to install Java and run the start.jlnp on that, to see if there's any difference. Any other ideas on your end? Thanks
  6. I had this same problem a couple of months ago. I am again unable to get the admin console to load. I've done everything I did when I had this same trouble before, but no results. The finder opens on the Windows desktop, but when I click on my ISY, then on LAN console, nothing happens. I have done the following: Cleared the Java cache using the Java control panel app. I checked all 3 boxes. I downloaded a new Start.jlnp, and ran it. Still no luck. I tried downloading the admin.jnlp file from the ISY directly. That didn't work. I tried all these steps sever times, rebooting the computer in between steps, and still had no luck. The last time I had this problem, I gave up, waited until the next day, repeated them, and it worked. No idea why. This has been very frustrating, to say the least. I'm even to the point of giving up on the ISY. Of course, UD want us whow own ISY's to update to the eisy, which has way more features than I have a need for, and costs a lot more. But, with the problems I've had lately, I'm not sure it's worth trusting the upgrade. So, any advice would be welcome. Thanks in advance.
  7. Yep, my first was a Model 1, tape recorder for program storage. Then moved up to a Model II, then Model III (I still have one of those in my basement), then a Model IV and even a Model 12! Shortly after, I think, the IBM PC's hit the market. Dating ourselves, aren't we!
  8. Geddy - Thanks for your response. I am runnning an ISY944 on Windows 11 with firmware 5.3.0, and have made sure I have the latest Java direct from Oracle's website. I was quite sure I had already done all that you suggested, but to no avail. However, I just followed your lead in your post to be sure (cleared the Java catch, downloaded a new copy of the Start app, etc.) and this time it worked. This reminds me of an article written by Jerry Pournelle years ago in Byte magazine, where he was explaining how to get a file transfer to work between 2 TRS-80 computers: "if you have everything connected properly, hold your mouth right and have the favor of angels, it just might work". I guess I just wasn't holding my mouth right before. Thanks again for your help.
  9. I've run into the same problem as posted above. All of the sudden, the IoX launcher will not open the ISY interface. The launcher opens, finds the ISY, but when I click on the entry, then on AdminConsole (LAN), nothing happens. I've cleared the Java cache, deleted and reinstalled Java, re-downloaded the start.jnlp file. I've power-cycled the ISY. Nothing works. I can ping the ISY's ip address, and the ISY is functioning. I just can't load its interface. I've had this happen before, but was able to get things working again, but not this time. Any suggestions would be appreciated.
  10. In my attempts to troubleshoot my loss of Alexa control, I opened the UD app on my phone, which reported that Izzy was not connected to the internet! So, I dug into the troubleshooting on the Wiki, and found a tip suggesting I take it off a static IP (which had worked for years), and set it back to DHCP. So, I did that, and that resulted in being unable to access it at all. So, I manually rebooted it (ie, power cycled it), redownloaded a new Iox launcher (as suggested in the Wiki), and that finally got me back into the admin console. So far, so good. I then looked at the UD app on my phone, and the "no connection" message was gone, and I could control lights via the app. And, voice control via Alexa was again working. Yippee! I have no idea which of my steps resulted in getting things back to normal, but I won't argue with sucess. However..... I have a new question. When I go back into the Admin Console, click on Help / About, the About screen shows "Internet access: Disabled". I frankly don't know if it used to show this in the past, although I'm pretty sure that would have set of alarm bells in my head if I had seen "disabled". Also, clicking on File / Enable internet access results in an error message "Failed Enabling Internet Access". So, is this referring to some other aspect of internet access, and if so, what the heck is it? Thanks
  11. I just discovered that I'm having the same problem. When I log into the portal, and click on Select Tool / Connectivity / Amazon Echo, I get a message saying "ISY is not online". The ISY is working fine with all other functions (lighting control), bu not through Alexa. I suspect this is a portal issue, and hope UD gets that straightened out ASAP.
  12. Thanks for the input. The "debouncing" at least explains the behaviour I was seeing. Thanks much again.
  13. I've sucessfully interfaced my ISY to Alexa for numerous lighting controls, etc. But I'm having a weird problem with the ISY's communication with Alexa via my portal for one particular purpose. I've connected my hard-wired doorbell button to an X10 Powerflash Interface and set its X10 code. When the doorbell is pressed, the X10 Powerflash sends an "On" signal to the ISY. (I can see this is working by viewing the ISY Event Viewer.) I've set up a state variable named $Doorbell. I created a program that sets $Doorbell to 1 when the X10 code is received, waits 1 second, and resets the $Doorbell variable back to 0. When I press the doorbell button, I can see the variable change to a 1, and then change back to zero. So, I know the ISY is correctly reacting to the doorbell button press. I've exposed the state variable to Alexa via my portal, and have created an Alexa routine to announce "Someone's at the door" when the doorbell is pressed. Here's where it gets weird. When I press the doorbell button, I hear all 4 of my Alexa devices announce "Someone's at the door". BUT, if, a few seconds later, I press the button again, I do NOT hear the announcement. If I then wait several minutes, the doorbell again triggers the announcement. It's as if there's a unexplained "waiting period" before the sequence sucessfully repeats as it should. So, does anyone have any ideas as to why there's such a delay between Alexa's reaction to subsequent button presses? Basically, my doorbell setup works, but not as I'm expecting it to. I think the problem is with Alexa, not the ISY. The delay may be attributed to the action of the portal, but I can't find any reason there. Any ideas would be appreciated.
  14. Thanks, oberkc. Tried that to no avail, but was worth a shot. Thanks
  15. Thanks for all the chatter regarding my question. In response to asbril's post, these Leviton switches were just recently purchased, and are labeled "ZWave Plus". Interesting to hear even older switches that once did respond to manual operation no longer do. That does seem to me like it could be a UD issue, and not the switches. I'm very new to the ISY, so have a recently purchased ISY994i with firmware v.5.3.0 and UI of Insteon_UD994 v.5.3.0. I did find a tip regarding writing a program to detect a Hail and then doing a query. That causes the ISY to now detect the status correctly (i.e. when the light is on by manual operation the ISY no longer shows "Off") but there still seems to be no way to determine if the switch was turned manually or by a program. Guess I'll need to wait to see if a firmware update from UD addresses this.
