  1. Tap the 3-dot menu (โ‹ฎ) in the top-right corner of the browser.
IPapp
  1. Oh without a doubt on the Beta version. However I wish I had dove into the form to see what pitfalls I may experience prior to setting everything up. The update to 5.5.3 appears to have fixed things. I wanted to use it for a week or so and see how it's been. The only issue I've had is nodes missing on a ZEN16 module and it seems that some of the configuration parameters won't push to certain devices.
  2. Strangest thing. Moving some ZWave devices to Eisy and what should be three On-Off Power Switches showing as Binary Switches. Only one On-Off Power Switch is listed. This was an issue some time ago with the 994 but I did not have this issue myself until the leap to Eisy. We are running: Firmware: IoX v.5.5.3 UI: IoX v.5.5.3
  3. @DavidV Thankfully I was not too far down the rabbit hole that I just powered up my trusty 994 and things are back to normal. I will just wait for an update that shows the issue resolved.
  4. It appears the wise thing to do was to wait. I started in not know there was an issue with the zwave migration. As it's been said, my eisy is stuck in a busy loop and nothing seems to work because of this. Is there any work around so at least the Insteon part of my home will work?
  5. Correct me if I am wrong but I recall a subject on building automatic reports that would capture trend charts and email them when a condition/schedule was met. Does anyone else recall this or am I way out in the weeds with this? Also, is there a way to schedule a report via email for a device? I have a heat trace for my gutters and the Z-Wave module that controls it has an energy meter. It would be really nice to track that kWh information without logging logging into my 994i PRO to obtain it.โšกโ„๏ธ๐Ÿ’ธ
  6. IPapp replied to IPapp's topic in ISY994
    Well so far so good today. I managed to change around some rules that I did not like. Not once did I have any access issues. I tried using IP Reservation and that turned into a circus of having to factory default my router. We will let things ride and see how it goes from here. I sincerely appreciate the pointers. I will frequently check the logs and see what comes to the surface! Again, thank you!
  7. IPapp replied to IPapp's topic in ISY994
    Thank you for the reply. The ethernet wiring is secure. The Power light is on bright and steady with the occasional pulsing of the Rx and Tx indicators. The ISY994 was purchased in December of 2019. The ISY portal license is active and expires in December of 2023. No apparent mismatch between the FW/UI. Strange thing is yet again it let me log in without an issue later tonight. Thank you.
  8. IPapp replied to IPapp's topic in ISY994
    Looks like it was simple as updating Java and nothing more. Everything is right back to working as intended. Thank you! ๐Ÿ˜ Well, or so I thought. Earlier in the day things were working and now they are not. There is a mixed bag of error codes in the log: -5012 -140000 -5013 -5010 -140005 -170001 There is a great deal of -140000 and -170001 errors almost less than one minute apart
  9. IPapp posted a topic in ISY994
    Good morning, all! Has anyone had issues with the Admin Console freezing at login? The ambler flag is displayed showing "busy" and the fields for the username and password cannot even be populated as the program itself is frozen. This happens in any attempt to login be it through LAN or Cloud. However, the ISY is running as it always does and most of the time UD Mobile works just fine as well. I have not updated anything at all. It was working one day and the next it was not. Looking for some pointers please. Currently running Java Version 8 Update 321 (build 1.8.0_321-b07) Thank you.
  10. What odds? I have that same module sitting on my desk at this moment. New in the box. Glad to hear it has been working out.
  11. I thought that I had noticed that option at one time, but was likely looking for something else at that time. I will do some playing around. Thank you!
  12. Good day, I am working on a generator notification project using the dry contacts inside my generators automatic transfer switch to change the input state on a Zooz ZEN17 module. The only struggle I am having is that when the power is lost and the load of the house transfers to the generator I am missing that status change from the ZEN17. When utility power returns and the ATS transfers back to utility I am able to receive that notification with no issue. Is there a way for the ISY994i to query the status of the ZEN17 once the ISY994i starts back up once generator power is available? One solution is to use a UPS for the ISY, router, modem, and ZEN17 but if it can be worked around with a program I would prefer that avenue. I would like to also follow the generator status so that I may write it a program for load shed/priority. Thanks everyone!
  13. I hate to say it but there has been zero progress with this. Sorry about the delay in reply, work has been a circus as of lately.
  14. Thank you for the insight!
  15. Having mostly insteon devices and now facing a lack of stock, what has been your luck with any specific make and model of Z-Wave devices? I am finding more frustration than anything no matter how many repeaters are installed, etc. Before I go "all in" on something I would like to have some confidence behind it. I didn't worry so much about insteon as it just worked more time than not. Their embedded modules were perfect as I use reproduction push button switches in my home which was built in 1919. I have a few Z-Wave devices on my desk right now which I removed with "much passion" today. They are inches from the trash. I am really looking forward to your feedback here.
  2. Tap Permissions โ†’ Notifications.
