RFiddletown
  1. Thank you DennisC...that works from home, can't wait to try it on the road.
  2. Another noob question... I want to access my ISY remotely (both the Admin and Dashboard) using one of my established Dyndns "Hosts". I can't figure out how to input the "URL" correctly into a browser to make the connection to my ISY [port forwarding for both http and https are active]. Thanks for helping this noob out...:)
  3. Thanks for the suggestion, I'll give it a try. When I "control" it from the ISY it responds as expected (Status is: On/Off) and a linked outlet turns on/off as expected. Looks like I'll have to get it to beep and send my wife around to find it! LOL
  4. Thank you for your help. The missing device is: 2472D Dual Band Outlet Link Dimmer v.41. So I assume it's located in the wall somewhere or is a "phantom". I'm migrating from a Hub and factory resetting all my devices would be extremely difficult. I think I'll just remove it from the devices list and see what happens. Thanks again...
  5. Thank you for your help. The missing device is: 2472D Dual Band Outlet Link Dimmer v.41. So I assume it's located in the wall somewhere or is a "phantom". I'm migrating from a Hub and factory resetting all my devices would be extremely difficult. I think I'll just remove it from the devices list and see what happens. Thanks again...
  6. Cannot locate a device that shows up in my "imported" list of devices, can the device be made to beep/buzz using a ISY command so I can track it down?
  7. I'm REALLY new to ISY so please be gentle! LOL I had the new ISY import all the setting from my previous Insteon installation. I then when through and renamed all the devices to my previous names. However, I now need to search/find within the Administrative Console if one of my devices is included in the new configuration by using the "address (e.g. 20.E7.D3) because I think I named it incorrectly. Is there a way to do so? Thanks
