SHladysh
  1. Bing! Right on the money. The simplest easiest fix - kudos to figuring it out Michael, I was truly stumped. So frustrated that I considered cloning my backup drive back to Mojave.
  2. Similar setup - only one scene tho with all switches. The rest of the kepad keys mirror one-to-one for switches that are remotely scattered in the room. I have the logic for each of the keypad keys controlling one switch, but if I use the remote switch to change the state, I want the keypad to reflect the switch's state - as opposed to the switch changing the light's state, and the keypad still lit up reflecting the ON state while the switch already turned it off. I think I follow the same reasoning as you're talking about right? PS And I figured out already how to have the LED bright when enabled, and dim when disabled - but still easily found in the dark.
  3. This is the closest I've come to solving/fixing, by following this: Admin Console Minimized/Invisible and Cannot be Restored This is usually related Admin Console state files not being updated properly and especially in case of multi monitors. All you need to do is to find the following files in Java temp directory (on Windows: c:\Users\[Username]\AppData\Local\Temp) and delete them. Or, you can simply search the computer for udi_*.* file patterns: udi_tree.state udi_frame.state udi_pgm.state udi_finder.state udi_launcher.state
  4. Worked on it for several hours. Cleaning, deleting, playing with all settings, running Java console, closing all running programs....all to no avail. SO I'm stuck with it. There are some dialogues that don't open in a window - and that means I have to Force Quit, since there are no keystrokes/mouse click/ that will close the full sized window. I'm officially stumped at this point - I have no idea when the ISY software creates a modal window and at other times does not, and creates a separate window. I AM starting from start.jnlp which creates a link on the desktop pointing to: /Users/stephen/Library/Application Support/Oracle/Java/Deployment/cache/6.0/bundles/ISY Launcher.app. So no, it's not starting from the browser - if only I could reset/set the different windows properties - so that when I select a submenu for a device it opens as a separate window instead of contained in the original window. Of course this all works fine on my MacBook Air running Mojave instead of Big Sur Java Web Start 11.271.2.09 Using JRE version 1.8.0_271-b09 Java HotSpot(TM) 64-Bit Server VM JRE expiration date: 17/02/21 12:00 AM console.user.home = /Users/stephen ---------------------------------------------------- ? clear console window f: finalize objects on finalization queue g: garbage collect h: display this help message m: print memory usage o: trigger logging p: reload proxy configuration q: hide console r: reload policy configuration s: dump system and deployment properties t: dump thread list v: dump thread stack 0-5: set trace level to <n> ---------------------------------------------------- java.io.FileNotFoundException: /Users/stephen/isy/udi_launcher.state (No such file or directory) at java.io.FileInputStream.open0(Native Method) at java.io.FileInputStream.open(FileInputStream.java:195) at java.io.FileInputStream.<init>(FileInputStream.java:138) at java.io.FileInputStream.<init>(FileInputStream.java:93) at com.universaldevices.isyfinder.ISYFinder.restoreState(Unknown Source) at com.universaldevices.isyfinder.ISYFinder.restoreState(Unknown Source) at com.universaldevices.isyfinder.ISYFinder$7.run(Unknown Source) https://isy.universal-devices.com/994i/5.3.0/insteon.jar https://isy.universal-devices.com/994i/5.3.0/ce.jar https://isy.universal-devices.com/994i/5.3.0/chart.jar https://isy.universal-devices.com/994i/5.3.0/fp.jar https://isy.universal-devices.com/994i/5.3.0/RXTX.jar Dump system properties ... ---------------------------------------------------- awt.toolkit = sun.lwawt.macosx.LWCToolkit file.encoding = UTF-8 file.encoding.pkg = sun.io file.separator = / gopherProxySet = false http.auth.serializeRequests = true https.protocols = TLSv1.2,TLSv1.1,TLSv1 java.awt.graphicsenv = sun.awt.CGraphicsEnvironment java.awt.printerjob = sun.lwawt.macosx.CPrinterJob java.class.path = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/deploy.jar java.class.version = 52.0 java.endorsed.dirs = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/endorsed java.ext.dirs = /Users/stephen/Library/Java/Extensions:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/ext:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java java.home = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home java.io.tmpdir = /var/folders/w0/rbh182vj6p9d2mtr6cb14c8m0000gn/T/ java.library.path = /Users/stephen/Library/Java/Extensions:/Library/Java/Extensions:/Network/Library/Java/Extensions:/System/Library/Java/Extensions:/usr/lib/java:. java.protocol.handler.pkgs = com.sun.javaws.net.protocol|com.sun.deploy.net.protocol|com.sun.deploy.net.protocol java.rmi.server.RMIClassLoaderSpi = com.sun.jnlp.JNLPRMIClassLoaderSpi java.runtime.name = Java(TM) SE Runtime Environment java.runtime.version = 1.8.0_271-b09 java.security.manager = java.security.policy = file:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/javaws.policy java.specification.name = Java Platform API Specification java.specification.vendor = Oracle Corporation java.specification.version = 1.8 java.vendor = Oracle Corporation java.vendor.url = http://java.oracle.com/ java.vendor.url.bug = http://bugreport.sun.com/bugreport/ java.version = 1.8.0_271 java.vm.info = mixed mode java.vm.name = Java HotSpot(TM) 64-Bit Server VM java.vm.specification.name = Java Virtual Machine Specification java.vm.specification.vendor = Oracle Corporation java.vm.specification.version = 1.8 java.vm.vendor = Oracle Corporation java.vm.version = 25.271-b09 javaplugin.proxy.config.type = unknown javawebstart.version = javaws-11.271.2.09 jnlp.tk = awt jnlpx.heapsize = NULL,NULL jnlpx.home = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin jnlpx.jvm = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java jnlpx.offline = false jnlpx.origFilenameArg = /Users/stephen/Downloads/start.jnlp jnlpx.relaunch = true jnlpx.remove = false jnlpx.session.data = jnlpx.splashport = -1 jnlpx.vmargs = LVhkZWJ1ZwA= line.separator = \n os.arch = x86_64 os.name = Mac OS X os.version = 10.16 path.separator = : sun.arch.data.model = 64 sun.awt.enableExtraMouseButtons = true sun.awt.warmup = true sun.boot.class.path = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/resources.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/rt.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/sunrsasign.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/jsse.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/jce.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/charsets.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/jfr.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/classes:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/javaws.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/deploy.jar:/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/plugin.jar sun.boot.library.path = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib sun.cpu.endian = little sun.cpu.isalist = sun.font.fontmanager = sun.font.CFontManager sun.io.unicode.encoding = UnicodeBig sun.java.command = com.sun.javaws.Main -notWebJava /Users/stephen/Library/Application Support/Oracle/Java/Deployment/cache/6.0/14/7f87040e-1011c439 sun.java.launcher = SUN_STANDARD sun.jnu.encoding = UTF-8 sun.management.compiler = HotSpot 64-Bit Tiered Compilers sun.os.patch.level = unknown trustProxy = true user.country = CA user.dir = /Users/stephen user.home = /Users/stephen user.language = en user.name = stephen user.timezone = America/Toronto ---------------------------------------------------- Dump deployment properties ... ---------------------------------------------------- active.deployment.proxy.bypass.local = false active.deployment.proxy.same = false active.deployment.proxy.type = 3 deployment.baseline.url = https://javadl-esd-secure.oracle.com/update/securitypack.jar deployment.cache.enabled = true deployment.cache.jarcompression = 0 deployment.cache.max.size = 4096 deployment.capture.mime.types = false deployment.console.startup.mode = SHOW deployment.control.panel.log = false deployment.expiration.check.enabled = true deployment.insecure.jres = PROMPT deployment.javafx.mode.enabled = true deployment.javapi.cache.update = false deployment.javapi.lifecycle.exception = false deployment.javapi.log.filename = deployment.javapi.runtime.type = 0 deployment.javapi.stop.timeout = 200 deployment.javapi.trace.filename = deployment.javaws.appicon.index = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/cache/6.0/appIcon/appIcon.xml deployment.javaws.associations = ASK_USER deployment.javaws.cache.update = false deployment.javaws.concurrentDownloads = 4 deployment.javaws.install = IF_HINT deployment.javaws.installURL = http://java.sun.com/products/autodl/j2se deployment.javaws.logFileName = deployment.javaws.muffin.max = 256 deployment.javaws.shortcut = ASK_UNTRUSTED deployment.javaws.splash.index = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/cache/6.0/splash/splash.xml deployment.javaws.traceFileName = deployment.javaws.uninstall.shortcut = false deployment.javaws.update.timeout = 1500 deployment.javaws.viewer.bounds = 651,463,1083,360 deployment.jpi.mode.new = true deployment.log = false deployment.macosx.check.update = true deployment.max.output.file.size = 10 deployment.max.output.files = 5 deployment.mime.types.use.default = true deployment.modified.timestamp = 1606370236112 deployment.proxy.bypass.local = false deployment.proxy.override.hosts = deployment.proxy.same = false deployment.proxy.type = 3 deployment.relaunch.increment.debug.port = true deployment.security.SSLv2Hello = false deployment.security.SSLv3 = false deployment.security.TLSv1 = true deployment.security.TLSv1.1 = true deployment.security.TLSv1.2 = true deployment.security.TLSv1.3 = false deployment.security.askgrantdialog.notinca = true deployment.security.askgrantdialog.show = true deployment.security.authenticator = true deployment.security.blacklist.check = true deployment.security.browser.keystore.use = true deployment.security.clientauth.keystore.auto = true deployment.security.disable = false deployment.security.esl.override.native.sandbox = false deployment.security.https.warning.show = false deployment.security.jsse.hostmismatch.warning = true deployment.security.level = VERY_HIGH deployment.security.local.applets = PROMPT deployment.security.mixcode = ENABLE deployment.security.notinca.warning = true deployment.security.password.cache = true deployment.security.permissions.manifest.required = true deployment.security.revocation.check = ALL_CERTIFICATES deployment.security.run.untrusted = PROMPT deployment.security.sandbox.awtwarningwindow = true deployment.security.sandbox.casigned = PROMPT deployment.security.sandbox.jnlp.enhanced = true deployment.security.sandbox.selfsigned = PROMPT deployment.security.tls.revocation.check = ALL_CERTIFICATES deployment.security.tls.validation.crl = true deployment.security.tls.validation.ocsp = true deployment.security.trusted.policy = deployment.security.use.insecure.launcher = false deployment.security.use.native.sandbox = false deployment.security.use.user.home.java.policy = false deployment.security.validation.crl = true deployment.security.validation.ocsp = true deployment.security.validation.ocsp.publisher = false deployment.system.security.blacklist = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/blacklist deployment.system.security.cacerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/cacerts deployment.system.security.jssecacerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/jssecacerts deployment.system.security.oldcacerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/cacerts deployment.system.security.oldjssecacerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/jssecacerts deployment.system.security.trusted.certs = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/trusted.certs deployment.system.security.trusted.clientauthcerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/trusted.clientcerts deployment.system.security.trusted.jssecerts = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/trusted.jssecerts deployment.system.security.trusted.libraries = /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/lib/security/trusted.libraries deployment.system.tray.icon = false deployment.trace = false deployment.update.mime.types = true deployment.user.cachedir = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/cache deployment.user.extdir = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/ext deployment.user.logdir = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/log deployment.user.logfile = jcp.trace deployment.user.logfile.append = false deployment.user.security.blacklist = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/blacklist deployment.user.security.blacklist.dynamic = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/blacklist.dynamic deployment.user.security.blacklisted.certs = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/blacklisted.certs deployment.user.security.exception.sites = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/exception.sites deployment.user.security.policy = file://Users/stephen/Library/Application%20Support/Oracle/Java/Deployment/security/java.policy deployment.user.security.sandbox.certs = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/sandbox.certs deployment.user.security.saved.credentials = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/auth.dat deployment.user.security.trusted.cacerts = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.cacerts deployment.user.security.trusted.certs = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.certs deployment.user.security.trusted.clientauthcerts = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.clientcerts deployment.user.security.trusted.jssecacerts = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.jssecacerts deployment.user.security.trusted.jssecerts = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.jssecerts deployment.user.security.trusted.libraries = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/security/trusted.libraries deployment.user.tmp = /Users/stephen/Library/Application Support/Oracle/Java/Deployment/tmp deployment.version = 8 deployment.webjava.enabled = true ---------------------------------------------------- Done.
  5. SHladysh changed their profile photo
  6. Everything is working EXCEPT one minor detail. I start ISY Launcher as normal, and it finds my ISY. I select admin console, and instead of opening the admin console in a new window it opens it as a tabbed window in the ISY launcher with the Authenticate dialogue floating on top as usual. I can authenticate, and then drag the admin console tab out of the ISY Launcher window so it's a separate window labeled admin console, and size accordingly. However opening anything that usually results in a dialogue window in the admin console, results in a tabbed window in the admin console that is the size of the admin console I can't acknowledge or click on any of the elements - and usually get out of the unresponsive dialogue tab with command/esc/return. How do I fix this behaviour? And where do I find the settings to tell it to open in it's own window, and remember for the next time? (I tried themes and fonts and reset to no avail). Stumped after exhaustive searches to find any hints or clues.
