JGoode
Everything posted by JGoode
  1. I would like to upgrade the firmware of my ISY. Current configuration is: I am confused what version to use for upgrade and where to find the link to get the file. Thanks for any help.
  2. I have seen some reference to a "Query all" program. I do not have that; it is possible I removed it not knowing what it was. I put in a short program to run between two times and included :Query" for the modules, and it only ran once but did update to the value that was manually set at the switch. I guess I don't understand how the ISY works since I would have thought it would have continually run this query if the time was within these limits.
  3. I am using an Insteon 2477 dimmer with my ISY994, and it works fine when controlled by the ISY, but it does not update the status automatically if the switch is turned on or off manually. The status is used in a program. It will update if I manually refresh from the ISY program, but I need it to refresh automatically. Is there a way to do that?
  4. MrBill, THANKS for the quick reply and suggestion. It worked perfectly! I am sure I will add more to my system, but for now it works great. Thanks again!
  5. I use an X10 outdoor RF motion sensor (A1 on trigger) to start a series of X10 commands. The issue is that the motion sensor sends multiple Ai on commands, and each one starts the macro, even while it is running. I have tried adding a state variable and only run the macro if the state variable is =0 with the first line in the macro setting the variable to >=1 then reset the variable to 0 at the end of the macro. The "then" is entered and the variable is set to 1, but the remaining commands of the "then" do not execute and the variable stays at "1". I am a newbee and I am sure it is something simple, but so far I have not been sucessful. I have a hardware solution that will create a single X10 signal (RF receiver plus 555 timer), but I am sure the 994 should be able to do this in software. Any suggestions would be appreciated.
