SSchuelke
  1. Support for Somfy Zigbee Shade Motors.
  2. Thanks. That worked and it did take a while...helped to do some yard work to help me "wait". Steve
  3. The link to enable PG3x doesn't work. The only thing that shows on the screen is the following message: This XML file does not appear to have any style information associated with it. The document tree is shown below.
  4. I am trying to upgrade to PG3x. I followed the instructions to use Admin Console to upgrade PG3 to PG3x. I am running 5.6.2 on Polisy and stuck means that PG3 only updates to 3.1.23 Upgrade Packages will not update further. I run on Windows 10.
  5. I'm stuck on v 3.1.23 and the log had the following message. 6/23/2023, 18:42:05 [pg3] info: ***************************************** 6/23/2023, 18:42:05 [pg3] info: Latest PG3 version available is 3.1.23_1 6/23/2023, 18:42:05 [pg3] info: ***************************************** Steve
  6. My Portal continuously disconnects. I reviewed the error log (attached) and get error -7066 consistently when the disconnects happen, I cannot find out what the -7066 error is about. No other device on my has disconnect errors. I attached a snippet from y error log that shows these errors. What is going on? Steve
  7. Although time will tell, Alexa seemed to work better after disabling the Mobilinc skill. I subsequently also removed and re-added all of my ISY smarthome scenes (really programs) using the Alexa app. sjenkens: I use both but most often Alexa. However I find GH is much more reliable but also more verbose with an annoying response every time I issue a smarthome command. larryllix: I also have weird issues similar to those you describe. I find they come and go... In any case these issues make me wish that I could purchase an in-house device with which I could trigger my smarthome voice controlled apps that would be easy to set up. +95% of my use of GH and Alexa is for this purpose. Does such a thing exist? I'll give another update about my slow Alexa in a week or so. Steve
  8. I just noticed that I have both the Mobilinc skill and the ISY Optimized for Smart Home V3 skill enabled. I recently switched from Mobilinc to the ISY portal. I just disabled the Mobilinc skill and will see if that helps.
  9. Over the past month or two our Alexa devices do not respond to voice commands as quickly as Google Home. I only execute programs using Alexa and Google devices. Google usually completes a command within 5 seconds. Alexa always takes at least 10 to 20 seconds and often does not complete a command. They both run on the same wireless Google WiFi network. Why would this be?
  10. MrBill - Support told me that the wiki is out of date on the 16 GB and that up to 32 GB is supported. Steve
  11. Thanks, Michel. I have a 32 GB and will be replacing it with a 16GB Memory Cards (SanDisk MicroSD Ultra) rated A1. For future reference, are there error messages or is there another way I can be notified earlier that my SD card is potentially going bad (other than irregular system behavior)? Also, in the SD card replacement instructions it says that "Please note: If your performing this whole process because of a corrupted SD card, a good backup is considered one that was completed successfully before the SD card got corrupted". I have taken a successful backup today that ran to the end without displaying any error on my screen. Is it OK to use that backup when restoring the card? The reason I ask is that I assume the zip file from the Backup ISY process contains my device information...I've recently installed many devices and scenes since the previous backup that I don't want to spend days getting them back. Thanks again. Steve
  12. Thanks Larry...I'll re-post.
  13. Exact one I ordered! Is a 16GB SanDisk MicroSD Ultra, 98MB/s Speed Class 10, SDHC, rated A1. I think my current 32 GB was also a SanDisk Ultra but can't remember for sure.
  14. Thanks, Michel. I have a 32 GB and will be replacing it with a 16GB Memory Cards (SanDisk MicroSD Ultra) rated A1. For future reference, are there error messages or is there another way I can be notified earlier that my SD card is potentially going bad (other than irregular system behavior)? Also, in the SD card replacement instructions it says that "Please note: If your performing this whole process because of a corrupted SD card, a good backup is considered one that was completed successfully before the SD card got corrupted". I have taken a successful backup today that ran to the end without displaying any error on my screen. Is it OK to use that backup when restoring the card? The reason I ask is that I assume the zip file from the Backup ISY process contains my device information...I've recently installed many devices and scenes since the previous backup that I don't want to spend days getting them back. Thanks again. Steve
