DVaslow
  1. Downloaded UD Mobile from Play store. Got it to recognize my ISY and set up both remote and local access successfully. However, when I try to save the system settings and allow the sync to run, I got a Java error and the process hangs. Error: java.lang. NullPointerException:NLS CMDP object requires a p_id FYI: ISY is running 5.3.0 and I restarted before I installed UD Mobile. Also, I have one node running on a local polyglot server (Hue Server). The error seems to happen when syncing that node. Is there a setting or something I need to change/set on either the ISY to get this to work. Thanks!
