BWalsack
Everything posted by BWalsack
  1. Just a heads-up on my start.win issue, that I discovered myself, is that if your monitor is plugged into HDMI 2, you will get a XFCE desktop with a mouse on the backround. If you connected your HDMI cable into HDMI port 1 you'll get a different XFCE desktop backround all together. Had me stumped for a while.
  2. Geddy, thanks for the reply and renaming tip. Start.win is an eisy, maybe freebsd question, not sure. I have the eisy hooked up to a monitor so when it boots I can see whats going on. Once it boots I can log in with admin/admin. (terminal / bash freebsd login, maybe) At the next prompt I can enter start.win which opens a windows UI. I've experienced 2 different desktops once start.win opens. The first desktop UI functioned properly before I migrated 994i to the eisy. After the migration to the eisy, when accessing freebsd with admin/admin and at the next prompt enter start.win I get a different desktop similar to the first but with a rat on it and no taskbar, must use ctrl alt delete to exit that screen. I'm not sure why.
  3. Migrate ISY994i (5.3.4) to Eisy (5.5.7) Recently purchased an eisy and cable from UD, and feel I've have migrated (nodes are functional) to the eisy. I have maybe 25 Insteon hardwired devices that are working fine with my isy994i (Firmware 5.3.4) and a 2413S PLM (2.4.2817), the eisy has 5.5.7 firmware. I do not have a Z-Wave network. I also have the mobile app installed on my andriod phone. Initially I was confused with the Admin Console configuration portal and the ISY Portal and now have a better understanding of each. When I opened IoX Finder before migration it showed both devices. Under name the eisy shows IoX, under for the 994i it shows ISY. Backups were done on both devices and the PLM was plugged into the eisy. Went ahead and restored the 994i backup to the eisy. Went to the eisy configuration tab and enabled INSTEON Suppport. User name and password to the same as the 994i. Feels good, right? Save and close eisy admin console. I open IoX Launcher again and under name the eisy shows ISY, under for the 994i it shows ISY. Can controll nodes on the eisy, but no Alexa or Google Assistant. Finally figured out where the ISY Portal and Migrate To option was and went ahead and did that. Alexa or Google Assistant funtionality worked. Questions: Did I loose IoX when I restored 994i backup to the eisy (IoX Finder says the name for the eisy is ISY)? Before I did all this, I was able to run Start.win on the eisy and it worked fine, nice desktop with a house. After restore and migration to the eisy, UD app works, can controll nodes, but Start.win is funky, desktop has a rat on it, no taskbar. I have to ctrl alt delete out. Opened a ticket, confused Michel quite a bit, thought I try here for some insight from the group. Thanks, Bo
  4. UD Team, I now have an eisy in hand and many insteon devices hard wired and working fine on my ISY994i. My plm has a rj45 jack which I think is incompatible with the eisy. I feel like I'm in limbo without a comprehensive setup guide for the eisy and have the same questions,expectations and intentions as Anton. I too am hoping for a detailed response from the team to Anton's questions and will be following this thread.
  5. I can access / login to my ISY portal remotely (Windows 10 & Brave), but after updating my ISY 994i to firmware 5.3.0 and installing the UD Mobile app on my pixel 4xl with android 11 (app has keyboard issues), I've got several issues. I can't login to my ISY locally, keep getting invalid credentials 401 (Error encrypting remote password please notify developer) or thru the local connection settings of the app. I didn't change my username or password before the update or the app install. I have cleared cache and storage, uninstalled app and reinstalled. Could use a hand with this. Thanks in advance!
