MBrzeski
Everything posted by MBrzeski
  1. MBrzeski replied to MBrzeski's topic in Flair
    OK. Thanks for your help. I think that this may be an OAuth 1.0 vs 2.0 issue. Flair has moved their authentication to OAuth 2.0 and I suspect the nodeserver is still using OAuth 1.0. I don't know much about OAuth, just trying to get my vents working!
  2. MBrzeski replied to MBrzeski's topic in Flair
    Thanks for the reply. I checked with Flair support and the credentials are now provided directly in the IOS app, which is what I have been using. Are there any delimiters required around the parameters (such as "SKJFKFKJFBEKFJ" or 'KSDFJFBSDFKJBFSDKJ') or just enter the raw parameter?
  3. MBrzeski posted a topic in Flair
    I am trying to run Flair nodeserver on Eisy/PG3. I have client_id and client_secret from Flair app, but not sure of exact syntax to enter into PG3 configuration screen. Can you provide some direction? Thanks. Maciek
  4. Alexa commands stopped working this evening, also UD mobile not connecting. Attempt to login to Portal at my.iso.io also failed Is portal down?
  5. That solved it. Thank you very much for the quick action. Maciek
  6. Strange problem this. I want to store power level in variable. Although I can see power level, online etc when I go to main device page, the items do not show up on the list of items on the program page. The Eagle-200 device does not show up under "condition" or "action" (if i want to store in variable). It only shows up on "action/query". I am also running Ecobee plugin, which works fine. Any suggestions. Thanks Maciek
  7. Alexa is down, and will not me log into portal. So I can’t submit a ticket.
  8. MBrzeski posted a topic in Ecobee
    Just added Ecobee plugin to Eisy Polyglot and never received a PIN to connect to my Ecobee account. Uninstalled, rebooted, reinstalled. No PIN. Tried to download error log and received file not found message. IoX log shows the following:- 2024-08-19 15:19:55.335 [pg3] info: Is client running? /var/polyglot/pg3/ns/0021b90268f9_1/logs/debug.log does not exist. 2024-08-19 15:19:56.692 [pg3] info: Downloading log package for nodeserver 00:21:b9:02:68:f9_1 2024-08-19 15:19:56.693 [pg3] error: downloadLog: Error: File not found: /var/polyglot/pg3/ns/0021b90268f9_1/logs/debug.log Any suggestions? Maciek
  9. Both Alexa and UD Mobile are down. Portal sign in gives 500 error.
  10. Same here. Alexa not seeing ISY, asks to restart skill, Mobile app not working, can't log in to Portal (500 error)
  11. MBrzeski replied to JGraham's topic in UD Portal
    All’s good. Thanks
  12. MBrzeski replied to JGraham's topic in UD Portal
    I am also down. ISY shows offline. Thanks for getting to this so quickly.
