JBalog
  1. I have shades attached to the bond node server which are showing up as On/Off. I would prefer them to be "dimmable" so I can set the position at a certain percentage of open as I can through the ISY. What information do you need to make an exception? Thanks for all your help.
  2. After updating the node server, deleting the nodes and then rediscovering them I can now set position for the shades by percentage. For me it also does not say the node is not updated to the latest version. I have the bond bridge pro. thanks
  3. I am actually using Rollease Acemeda shades with the bond bridge. The Bond Bridge actually does have a feature for "set position" to a certain percentage open for Rollese Acameda and it is available on the homeassistant version of the plugin.
  4. Any plans to make shade set position available for programming? The home assistant version o the plugin seems to make the set position available to programming. The status reports the percentage open, but there does not seem to be a way to command it to open or close partly to a "percentage open". I would be happy to beta test it.
  5. Now that the i3 keypads are available I tried to order the etching at your website, but I cannot find a link for the i3 keypad
  6. I am pretty sure I am using the wrong syntax below as the program I intended to make a notification if a garage door is open for more than 10 minutes actually alerts on open/close state change. Alternatively, the current state duration is not updated at the same time as the open/close state, causing an alert on state change as the current state duration may actually be denoting the duration of the prior open/close state. Would anyone correct this by using a state variable in the ISY program? Program Content for 'Garage doors are open too long' If 'Garage / MyQ Bridge / Left Garage Door' Door State is not Closed And 'Garage / MyQ Bridge / Left Garage Door' Duration of Current State > 600 seconds Or ( 'Garage / MyQ Bridge / Right Garage Door' Door State is not Closed And 'Garage / MyQ Bridge / Right Garage Door' Duration of Current State > 600 seconds ) Then Send Notification to 'Text Both' content 'Garage.Doors.Open.Too.Long' Wait 10 minutes Run Program 'Garage doors are open too long' (If)
  7. Thank you. I understand it is not supported. You did mention manually entering the addresses of nodes to export at one point in the discussion with Michel. I thought that manually editing the xml file from the isy994 might work but I guess not. Thank you for all your hard work in making the Node Server.
  8. I was trying to manually edit the file I used to import nodes from my Isy to elkrp to direct it to the polisy as my nodes have not changed but it does not look like there is an address of the Isy/polisy in the xml file. How does the elk m1 know what to communicate with?
  9. In the past using the ELK module I had exported scenes to the EL and even my garage door statuses through the MyQ node server. After transitioning to polisy and the ELK node server I cannot get the ELK to control the scenes/nodes through rules or directly selecting the "lighting" from the ELK automation menu. The nodes are the same as when PG3 was directed to the ISY994. The ELK node server in PG3 shows the scenes and the garage doors that were exported to ELK as Nodes as light_1, light_2, light_3... etc. Is there any way to get the ELK rules to control an ISY scene now?
  10. on free node servers the install button also does not start a download either. On the node server purchases website when I click refresh listing I get requested PID not found.
  11. I am not being redirected to the UDI purchasing portal. This had been working before, but not in this version. It also does not work in firefox in addition to safari. I have not changed my firewall.
  12. I am using Safari as the web browser
  13. I tried to purchase and install the MyQ Node server (PG 3.1.11). Clicking either purchase or activate (for the free trial) does not seem to do anything or install the Node server. I restarted PG3 and my ISY (I am currently using the ISY994i as I was planning to migrate to IoP once I receive the Zmatter card. Thanks, Josh
  14. I have been using my polisy box for ~6 months. After upgrading the packages I cannot login to the web dashboard. After factory resetting the unit I can login via ssh but not the web dashboard.
