RLaFrentz
  1. Please Help, Just installed a new ISY system and migrated over from my existing Hub. I have a few range extenders, they don't show up in the Admin. Console when I try to add them. When doing a auto discover, the system says they are not supported.... Don't we need these range extenders for good communications ?
  2. I am having the same type issue..... Just moved my system from the Insteon Hub to this system. Now the garage door status of open / closed does not seem to work right. The status of the Sensor in the Admin C. stays "ON" when I open the door.... should say "OFF" , even after waiting several minuets. BUT WAIT TILL YOU HERE THIS..... Then... when I close the door,,,,, it changes to "OFF".... but the door is closed. It is like it takes two hits (or changes of state) to make a change on the sensor status. the door goes up and down just fine, right away. If I do a manual query of the status of a garage door sensor... the status changes to "On or "OFF" when as it should, but it does not seem to want to change by itself. Every night when the unit does a full system query, the status is not right. Old Hub worked just fine, 3 garage doors have worked with the hub, the open close status has always show up quickly. HOLD ON....... just figured it out..... It seems like it needed a cycle of the doors going up and down to link it up and be reliable. strange... but it now works.
