Dishboy007
  1. I did put a ticket in. They gave me a few options on how to fix it. I decided to move to Eisy. It is a solid state drive. Just wandering if I'm able to but another operating system on it, headless Linux or Home Assistant?
  2. Can I use an old Polisy for anything? The hard drive went corrupt and I moved to Eisy. Can I put another operating system on it?
  3. Thanks, I just wanted to make sure it was safe to use.
  4. I have a original Insteon dual outlet in my attic. The top outlet turns on/off a small Leg Lamp that sits in a small window at night. I noticed the lamp wasn't turning on. The led bulb was bad. I put a new one on and it worked fine, but I noticed the red led status light not working. The green works and the green and the red work on the bottom outlet. Doesn't seem like a big deal, just thought I'd check. I did do a hard reset and still didn't work. I don't need it. I'm never up there anyway.
  5. It's connected. Thanks!
  6. Re-entered the password and tried the power. No luck.
  7. I updated to 5.5.9. It showed disconnected after the update.
  8. Dishboy007 posted a topic in IoX Support
    Anyone know why it is disconnected?
  9. I have a couple of 2843-222 I wanted to use on my mailbox and package box. I really liked the waterproof boxes you got. Has anyone had problems with batteries exploding in the winter? I had one blow up one winter and the battery acid ate though the sensor board. I was using a lithium ion battery. It did happen in a especially cold winter in Indianapolis.
  10. I got mine yesterday.
