Mirgo
  1. I believe i answer you Ross, but don't see my reply. There is no down side, I have it for 4 years now with no problems, the jumper engages hvac circulating fan when heater is on. Without jumper it will work only with AC turned on. I can explain in more detail why and how if someone really need it.
  2. Mirgo started following Michel Kohanim
  3. I did this, for standard heat pump systems. Hope it helps.
  4. Mirgo joined the community
  5. If anyone still needs information on how to hook-up 2441th to a heat pump, I can explain. ;-)
