jrf
  1. I'd guess around 7-8 years, it pre-dates dual-band. I was thinking about picking up a new spare anyways. Guess I'll make that an order for 2, one to put in now, one for later. I'm assuming the process to swap PLMs hasn't changed. Unplug everything. Plug in PLM. Let it power up. Plug in ISY. Let it power up. Log in. Restore PLM from ISY admin console. Drink responsibly. Can someone confirm? Thanks again.
  2. Ok....added another MS.... it added correctly....mostly. It was added and appeared in the list...but it showed pending writes. So I forced a write updates to device... it completed successfully. And...it reported status (motion) changes. And....suddenly....now.... So is everything else. All motion sensors, trigger lincs, and moisture sensors are reporting status. Not a full moon tonight, so I'm going to go with something stuck in it's digital throat (or craw). All seems to be working properly now. I'll continue to monitor. Way weirdo. Will watch for a few weeks and then see about updating to 4.6.2. Big thanks to you help and suggestions. I have a fairly complex automation environment at home, with Homeseer at the heart of it all. I appreciate all the help I get from the HA community of trailblazers.
  3. Thanks for the welcome. I've been lurking/monitoring the forums for years. All my wired and plug in devices report status and operate normally across both phases. I did a power cycle (unplug /replug of the PLM) but only did a restart of the ISY. I did an unplug/replug there too. No Luck. There are plug ins upstream and downstream of the PLM (same circuit). Both work as do all the rest in the house. The odd thing is that everything else is working including remotelincs.. Various keypad links throughout the house all work, remotelincs control both wired and plug in devices, and the console is controlling things throughout the house. If I take the battery out of a MS and query it...it recognizes that there's no power there. I put it back in and query it and it sees the batter. The weird thing is that they've all gone radio silent at the same time, makes me think it's something "central".... or upstream from the individual MS/Moisture Sensors/Trigger Links. I triggers a moisture sensor. I see the light turn on showing a transmit. No change in the Console. Still blank. Same with Motion and Trigger links. Is see them "send" but I don't see a status change in the console. I'm going to go grab a new MS from my spares pool and see if I can add it.
  4. After several years of reliable service from my ISY and insteon network, I've hit my first real snag...and it's a doozy. Suddenly a few days ago, I was no longer seeing changes to motion sensors, leak sensors and trigger lincs. I have 24 motion sensors, 12 leak sensors and 25 triggerlincs. None of them report status changes. Not a one. Now, the plot thickens.... If I query the Battery Status for the Motion Sensors, I get a battery report/status right back and it's right. Querying Motion or Dusk Dawn is blank. My remotelincs are working properly and response/control of other devices (both hard wired and plug in mondules) is nearly instant as it always has. I have dozens of dual band devices and some range extenders. Controlling devices through the console is also working. I haven't added or deleted any devices in weeks. I'm on version 4.5.4.....(downrev I know, but it's been 100% reliable so I wasn't going to go to 4.6.2.) I've already done a restart of the ISY. No change, except the values that were there before and not changing are now blank and not changing. Anyone?
