palacekeeper
  1. Update: I didn't notice it right away because the IP address changed. It appears to be working after running the commands that Michel provided, as follows: ----- " Hi James, I am so very sorry to hear. If you can ssh or login directly, please do this: sudo pkg install -f isy sudo pkg install -f udx sudo tail -f /var/udx/logs/log ... wait till it either errors out (let me know the error) or successfully starts. If successfully starts: sudo shutdown -r now If it errors out, please let me know the error." ----- So, to clarify, when I ran the first two commands I got the prompt back very quickly, so I wasn't sure if I should run the tail command right after. I tried it and got a few errors but then a little later the second command apparently finished and it rebooted. After that I reconnected and ran the tail command (was just for logs I'm assuming but no big deal to run it for future reference). Later I noticed on my phone that it had come back up (from the app) so I went in and tried IoX which worked with a new IP it grabbed. Everything seems to look okay and I ran a few tests which worked. Interestingly, the 3 landscape light switches all still work - even though I added them to the old ISY system yesterday. I shut down the ISY and as of now the EISY seems to be back up and running fine. Added bonus - in the process it upgraded to version 5.9.1 Kudos to Michel!
  2. I tried it again and it runs successfully but doesn't fix anything. After every reboot I have to tell it to release/renew an IP address in order to connect again. Once connected, no changes and still in the same state. Michel responded to my ticket this morning and sent me some commands to run. As far as I can tell, those commands didn't fix anything yet. After running those, I can no longer connect with IoX. I'll reply back with any significant updates and hopefully a resolution once Michel provides next steps.
  3. Yeah I did that last evening. Just waiting to hear back. In the meantime trying to make some progress but epic fail so far. Sent from my iPhone using Tapatalk
  4. Yes I can ssh to it, and I attempted the command suggested earlier, assumedly to force the packages install and reboot. Didn't work though. I got several lines of "pkg: An error occured while fetching package", "unable to update repository udi" and "error updating repositories" All attempts to factory reset have failed so either it's half bricked or I'm doing it wrong. I've tried pushing the button 10 times both when its up with a blue power button and when its down with a red power button.
  5. Sorry if it wasn’t clear. I got into the old isy994 and added my lights outside to the old system for now. Now I’m back to trying to factory reset the eisy. Was the ssh suggestion for the factory reset of the eisy? Sent from my iPhone using Tapatalk
  6. I didn't try the 8080 but did try the other one. I was able to get in by using the portal, but I had to pony up another $44 for my old ISY license because it wouldn't function until I renewed the license. Oh well, at least for now I was able to add the outside lighting into the old system until I get some help for UD support. What's especially odd about this, though, is that the EISY won't even factory reset, but it will let me log in to the admin console. Things like time zone don't seem to sync, I can't uncheck network settings options, it won't reboot or restart IoX within the console, etc. All I should have to do to factory reset is push the little reset button 10 times, correct? Am I missing something?
  7. yes I can ping it, and I verified that the IP is correct - even power cycled with a ping -t and watched it go off and back on. The launcher won't add it and a browser says ERR_CONNECTION_REFUSED
  8. So even pushing the button 10 times did not seem to revert to factory because it still isn't getting an IP address on its own. Now when I assigned it IoX finds it but no longer shows the menu to start the console. Totally sucks. For the old ISY, should I be able to use the same IoX launcher to connect to it? I have the ISY994 up and using a static IP that I had set up in the past, but IoX won't find it and won't connect by IP address. I tried both http://1.2.3.4/desc format and http://1.2.3.4:8443/desc and both with https but I get Not Found. I also cleared Java cache, apps, etc. Is there something I need to do in order to be able to connect to the old one using the currently installed Java and Iox? Thanks.
  9. ok thanks Dennis. I did try pushing the reset button 10 times, but it's been 20 minutes and still on the red light. I suspect it did nothing like the other things I tried, but I will wait longer to try bringing it back up again. in the meantime, I will probably bring up the old ISY994 and add the landscape lights back on that one. It's a security issue because we are in the middle of the woods, and it's pitch black out there without them!
  10. Thanks Jimini, that information was helpful. I was not aware of the red/blue sequence causing an update. In fact, my intent was to power off the device before unplugging it and must have ended up with it coming back on to upgrade. In any case, I tried the red/blue sequence again, but in my case it didn't make any difference. I did open a ticket but since it was on Friday I'm floating helpless until Monday because I'm doubtful that support will help over the weekend, and unable to control my landscape lights outside (it's so dark!). It's in an odd state at this point: 1. I can get into the console locally with a monitor and keyboard. 2. DHCP doesn't work on its own but I can use a sudo command to release/renew an IP, which is enough to connect using IoX. 3. In the IoX, all of my devices and programs are there, and I did a backup in its current state, but the Zwave menu is unavailable/not responding. 4. I tried the reset button 5 times for reboot, and also 6 times to reset the zwave dongle. Both seemed to have yielded nothing. After the 6 button presses the power button has been red for about 15 minutes so far, so I tried pushing the power button to see if it changes to blue, but it stayed red. I'm thinking it could still be resetting the dongle or doing nothing at all. Who knows!? Nothing on the screen of the connected monitor, though. 5. Next I'm thinking of 10 presses for a factory reset and then maybe restoring whatever backup I have OR following the migration backup/restore that I did almost a year ago, but of course I'd lose my changes since then. If you or anyone else is reading this and have any other ideas, I'd appreciate anything else to try! Thanks, I did open one last night, but since I'll be down the whole weekend waiting on a response on Monday I'm trying to find other solutions in the meantime.
  11. I was doing some maintenance on my servers and unplugged the EISY. Later on my phone I noticed that it appears it may have been in the middle of an upgrade when it was powered off because there was a notification from the EISY app that it was upgrading. After that it wouldn't come back up correctly. I was not aware that it was upgrading nor was I aware that it would upgrade on its own! I am able to get to the console with a monitor and keyboard and logon with default admin account, and I was able to set the dhcp address and login with iox and the admin console. At this point I can log into the admin console with my usual credentials and see my devices, programs etc. but none of them work if I try to turn them on. Anything I try says request failed. All devices are zwave. The Z-wave menu says "Zmatter z-wave not responding". I've tried powering off and removing the zwave dongle and plugging it back it, but no luck. It does show up on the computer in device manager, but with ? icons - not sure if that is normal. HELP! Other symptoms are that it doesn't seem to reboot remotely from the admin console and restarting iox from the admin console does nothing. logs show "0 null Fri 2025/03/07 08:54:23 PM System Unknown " repeatedly but with updated timestamps, of course. I would consider trying a factory reset but before I try anything else I wanted to see what you recommend next. I do have backups including zwave devices if needed, but they are a couple months old. That would be fine but I need guidance on what to do next and whether to try a factory reset. I can't control any lights. what a mess! Thanks!
  12. Hey SBernard, thanks for the follow up suggestion. The workaround of using the Alexa app to control the scene/routine has been working well, but I would like to be able to get it to work reliably natively also at some point. I've been using DHCP reservations all along, so I don't think a static IP will make a difference in my situation, but it is definitely worth a try! I have a spare Govee bulb I haven't set up yet so maybe I'll give it a static IP and give it a try for testing purposes. Thanks again!
  13. I'll probably experiment with this just because I'm curious :-). by the way, I checked and Alexa routines do allow you to be more granular with regards to setting schedules, where you can do offsets, times of day, etc. Either way, the current way I have it set up with Alexa routine running an EISY scene first, and then running the Govee commands directly afterwards, is working well and seems to be a decent workaround. Sams Club has the Govee bulbs pretty cheap and they seem to be pretty reliable so far, and reasonably well made. I've had Govee temp/humidity sensors for quite a while and they are very reliable.
  14. interesting idea. One advantage to doing it that way (although I'm not sure how it would be done) would be that I think setting schedules in Alexa routines is limited to dusk and dawn - unlike the flexibility in EISY, but I haven't messed with it yet so there may be other ways to tweak the timing in Alexa routines
  15. Does anyone know if the GE Cync bulbs will work with EISY? I didn't see any nodes in the PG3 store for it but I may have overlooked it or it could be under another node name. Thanks
