RRaymond
Everything posted by RRaymond
  1. Windows 10. I did disable the Windows software firewall but it still didn't help.
  2. Thank you. Manually adding with http://10.0.1.190/desc works but I'm unsure why it won't find ISY on the network anymore. Must be something interfering with UDP broadcasting on the subnet?
  3. The ISY finder loads, and it used to be able to find my isy device but no longer can. I have tried a few things but nothing works: 1) cleaned java cache/temp files, reinstalled isy finder 2) telnet to ISY device with IP (works), logged in, confirmed that IP is dynamic, and IP assigned is proper on my network 3) If I select "add" and specify: http://10.0.1.90, it says not found (even though this is the telnet IP). Any other option won't load. 4) I am on the same network, I only have 10.0.1.x subnet. I can ping + telnet to ISY device from the machine 5) turned off windows firewall to all networks (just to verify it's not interfering) FYI - I can load the ISY web portal by visiting URL but I can't load admin console because it can't get past the isy finder screen.
