PAstrachan
Everything posted by PAstrachan
  1. That is odd then - it doesn't always trigger. Maybe I need to reboot it. This is all I have for that program. If the pathlight is on then turn on the external plug Sometimes this works and other times it doesn't seem to turn off. RIght now it is working fine. Maybe I have some conflict with another program. I'll look into that
  2. I have an external switch and instead of using it as a receiver, I just have a program that says if a specific light status == on (for another light) then turn external switch on. Else turn the switch off. However, it doesn't get triggered when I turn the light on /off. What tiggers the programs to run?
  3. Appreciate all the offers to help - great community.
  4. I did get this working. Documenting what I have in case it helps anyone. I'm using a routine in alexa to run entrymonvar program on ISY Anytime the front door sees motion, alexa turns on the entrymonvar program When motion is not seen for 10 minutes alexa turns off the entrymonvar program The entrymonvar program entrymonitorvar - [ID 0010][Parent 0001] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then $motion = 1 Run Program 'axexamontionprog' (If) Else $motion = 0 Run Program 'motionmain' (If) The axexamontionprog axexamontionprog - [ID 0011][Parent 0001] If From Sunset To Sunrise (next day) And $motion is 1 Then Run Program 'motionmain' (If) Else - No Actions - (To add one, press 'Action') The motionmain program motionmain - [ID 0013][Parent 0001] If $entry_var is 1 Or $motion is 1 Then Set 'Front Entry' On Else Set 'Front Entry' Off And finally the entryvar program entryvar - [ID 0012][Parent 0001] If 'breakkey_a' Status is Off #####(this was the one that was missing)######## Then $entry_var = 0 Run Program 'motionmain' (If) Else $entry_var = 1 Run Program 'motionmain' (If) This seems like overkill to use 4 programs and 2 variables but it does work. The idea here was that the light would stay on if it was turned on by a scene. If motion turned it on, then only the switch was turned on, so I could use the status of another switch in the scene to see that it was motion that turned in on or the switch directly.
  5. What the program did was when there was motion from the Ring, it would turn the front lights on for a couple minutes and toggle them off, but if the light was already on, it would stay on. I used a couple programs to get this to work. I'll post later tonight the actual programs. I think I was directly controlling the switch to turn it on, but looking at the scene to see if it was already on.
  6. I get this message in the program in the if statement. I can't remember what I was looking at. I think it was the status of the switch. How can I tell what condition this was looking for? Warning: Unrecognized Condition (program may not run) <status OP="IS" NODE="7 E5 1C 3" ID="ST"> <val UOM="51" PREC="0">0</val> </status>
  7. I did the firmware update locally from the ISY launcher APP on my Mac. UD mobile works correctly now and all the files that were previously missing are there now Thanks for the help
  8. Ok - I tried on the portal but it doesn't let you overwrite with the same version. I'll see if I can get logged in without the portal.
  9. This is the result of running the query you stated This XML file does not appear to have any style information associated with it. The document tree is shown below. <profiles> <profile family="1" id="1"> <files dir="NLS"/> <files dir="EDITOR"/> <files dir="NODEDEF"/> <files dir="EMAP"/> </profile> </profiles>
  10. Firmware version is 5.3.0 - however I was at 4.7 when I tried to install the APP and updated and then the sync worked No errors when synchronizing after updating the firmware. I've included a screenshot from my phone of what I see
  11. I downloaded UD mobile set it all up and I can see all the devices and scenes on my ISY. However, for a light, there is no control that shows up to turn it on/off, adjust the brightness etc. Is this expected? I don't have a polygot server running. Is this a requirement?
