PBatavia01
Everything posted by PBatavia01
  1. Thanks! I know I don't unzip the backup file - I was just looking in it out of curiosity, and was surprised there were no visible files in the archive, and it was only 34kb.
  2. Hello, After MANY years of very reliable ISY994i operation, I've ordered the latest eisy. The 994i still works well, but I don't want to press my luck. I've seen the posts and documents about migrating from polisy to eisy by just doing a backup and restore, and wanted to confirm that pathway works for 9994i -> eisy also. I'm on what I believe is the latest / last firmware for the 994i - 5.3.4. One strange thing. When I do a backup from the admin console, it downloads a .zip file (which contains another .zip file) - but that file is empty. AFTER the download happens, I see a lot of console activity as if a backup was being created. But nothing downloads after that. Am I missing something? Thanks!
  3. I'm getting back to Polisy after a long while, since I want to move over to IoP. I'm currently at PG2. After doing an update, I show that I'm at Version 2.2.13, Frontend Version 2.2.9-5, ISY Version 5.3.4. I assume I need to update to PG3 via SSH? I tried to find a wiki page with instructions, but failed. The closest I could find was this: PG3 Instructions - Universal Devices - The Most Powerful Automation, Energy Management, and IoT Platform (universal-devices.com) which has a series of install and service commands. But before I do this, I wanted to confirm I wasn't missing anything else. Thanks for any help or pointers!
  4. So I think I'm seeing this also. None of my scenes are working, but individual devices are still working. No idea what's happening.
  5. Hello, I've got a Pentair Intellicenter, and I saw the pool nodeserver, and decided to give it a try. It does show a pool controller, but doesn't populate it with any nodes - and from looking at the log output (pasted below), it looks like maybe the intellicenter isn't supported? 2021-05-20 12:54:17,645 MQTT polyinterface INFO polyinterface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2021-05-20 12:54:17,690 NodeServer polyinterface INFO pool-poly:start: Starting Pool Controller Polyglot v2 NodeServer version 1.0.0 2021-05-20 12:54:17,723 NodeServer polyinterface ERROR pool-poly:start: Error reading NodeJs Pool Controller API url from Polyglot Configuration: HTTPConnectionPool(host='localhost', port=3000): Max retries exceeded with url: /all (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x802bc5b50>: Failed to establish a new connection: [Errno 61] Connection refused')) 2021-05-20 12:54:22,724 Controller polyinterface ERROR polyinterface:write: Exception in thread Controller: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn (self._dns_host, self.port), self.timeout, **extra_kw File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection raise err File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection sock.connect(sa) ConnectionRefusedError: [Errno 61] Connection refused During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen chunked=chunked, File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 392, in _make_request conn.request(method, url, **httplib_request_kw) File "/usr/local/lib/python3.7/http/client.py", line 1277, in request self._send_request(method, url, body, headers, encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1323, in _send_request self.endheaders(body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1272, in endheaders self._send_output(message_body, encode_chunked=encode_chunked) File "/usr/local/lib/python3.7/http/client.py", line 1032, in _send_output self.send(msg) File "/usr/local/lib/python3.7/http/client.py", line 972, in send self.connect() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 187, in connect conn = self._new_conn() File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 172, in _new_conn self, "Failed to establish a new connection: %s" % e urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x802bb8150>: Failed to establish a new connection: [Errno 61] Connection refused During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send timeout=timeout File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 727, in urlopen method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2] File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 446, in increment raise MaxRetryError(_pool, url, error or ResponseError(cause)) urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='localhost', port=3000): Max retries exceeded with url: /all (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x802bb8150>: Failed to establish a new connection: [Errno 61] Connection refused')) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/threading.py", line 926, in _bootstrap_inner self.run() File "/usr/local/lib/python3.7/threading.py", line 870, in run self._target(*self._args, **self._kwargs) File "/var/polyglot/.local/lib/python3.7/site-packages/polyinterface/polyinterface.py", line 852, in _parseInput self.shortPoll() File "./pool-poly.py", line 81, in shortPoll self.nodes[node].update() File "./pool-poly.py", line 121, in update controllerData = requests.get(url='{}/all'.format(self.apiBaseUrl)) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 75, in get return request('get', url, params=params, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 60, in request return session.request(method=method, url=url, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request resp = self.send(prep, **send_kwargs) File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send r = adapter.send(request, **kwargs) File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send raise ConnectionError(e, request=request) requests.exceptions.ConnectionError: HTTPConnectionPool(host='localhost', port=3000): Max retries exceeded with url: /all (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x802bb8150>: Failed to establish a new connection: [Errno 61] Connection refused')) Has anyone gotten the pool nodeserver to work with intellicenter? Thanks!
