mglacey
  1. mglacey replied to hart2hart's topic in ISY994
    Hi Mike, Awesome. Thank you. Wish me luck. I see a good day or two of playing in my future. Mitch
  2. mglacey replied to hart2hart's topic in ISY994
    Thank Thank you Mike! I'm just getting into the variables now and it's really nice to see examples. I think my C++ brain is way overthinking things. And... Why don't you use state variables instead of intergers?
  3. mglacey replied to hart2hart's topic in ISY994
    Hi Mike, I was wondering if you could take a screen shot of this page please. Mitch
  4. mglacey replied to hart2hart's topic in ISY994
    Hi Dwight. What I did was delete the lock from "my lighting" tree, then I went to zwave and clicked remove, then set the sequence on the lock, which removed it. Then I re-added it by having the ISY listen for the enroll event and initiated the enroll on the lock. It took a couple times of doing this, but it worked and now I see the communication. When I first enrolled it, it was the only zwave device. I since added a wall outlet and a plug in repeater, and it works flawlessly. The repeater and outlet are about 10' from the lock. Mitch
  5. mglacey replied to hart2hart's topic in ISY994
    Hi Mike, After I removed and re-added the lock, I can now see Alarm status field populated like in your screen shot! Nice! Favor, would you be willing to share a screen shot of your Variables tab for your iSchlageUnLockedBy and iSchlageLockedBy? Remove all personal data of course. Mitch
  6. mglacey replied to hart2hart's topic in ISY994
    Hi Mike. I am running 4.55 and have ISY firmware 4.2.23. What's missing is the activity in the event viewer. If I lock the lock with the ISY, I see activity. If I use a code on the keypad, I do not. That's what's driving me crazy. Looking at your screen shot, what is missing from mine is "alarm". You can see I just have deadbolt and battery level. If I lock through the ISY, I get that field, however it is not populated (lock2.png). Would this be a signal issue? I have two z-wave electrical devices within 10 feet of the lock on either side. I'll keep playing around. I'm going to delete everything, remove the lock, re-add it and then re-add your scripts since I know they are working. Grrr. Mitch
  7. mglacey replied to hart2hart's topic in ISY994
    Hi Make, et al. Curious. I set up my new lock with the 994i just like you have in your post, but for whatever reason the ISY will not detect the current lock state. If I query the lock, and I have programs enabled, they run and light up the house. However, in normal use, like coming home and unlocking the door at night, with a simple "turn on entry light" program setup, the communication from the lock to the ISY never happens, and the lights never turn on. If I open the console, query the lock - no problem. When you set this up, did you have to change any settings on the lock or the ISY to have it check status, or to have the lock send status? It's driving me bonkers. Mitch
