theedudenator
  1. I am a bit lost on how this is made, and how does it count? $iMotionCount < 5
  2. I have a motion on the back of my house that is running though my ELK M1 I have an ISY program to turn a light on when motion is sensed. The problem is the motion sensor seems too sensitive, not sure if bugs or birds are triggering it. Is there options in a program to sense multiple motion events with a time limit to trigger the lights?
  3. Only seeing one zwave device, but it doesn't have built in GFCI like the radiant floor manufacture wants. I am now thinking of just buying the cheap non-programable floor thermostat and using a higher amp zwave switch to stop/start the entire system. Any thoughts or suggestions?
  4. Should use Linux and deal with Java. I am to the point of looking for something aside from ISY cause of the use of unsupported Java Sent from my SM-G973U using Tapatalk
  5. Upgrade process is convoluted. No clue why it can't auto be done through the software... Sent from my SM-G973U using Tapatalk
  6. I ment EBAY!!! Paypal is fine. Sent from my SM-G973U using Tapatalk
  7. I have stuff I have swapped over the years, including a new PLM. Any place to sell this stuff? Been trying local, and won't use Paypal Sent from my SM-G973U using Tapatalk
  8. I bought the new 500 module and updated to 5.3.0. Now I have all this extra stuff, is it normal?
  9. I have 3 older Honeywells in our house, no issues.
  10. I can see my isy99 in the portal. When I try to do web access nothing happens. Loading config
  11. Exactly what happened to me multiple times. I have a new never used PLM I want to sell... Sent from my SM-G973U using Tapatalk
  12. I guess I dont. Just installed the zwave only firmware, now I need to replace 5 devices... Sent from my SM-G955U using Tapatalk
  13. I think I need the PLM for ELK integration.
  14. Every 8monts to a year I have a PLM failure.... 80% of my devices are zwave 20% are insteon I have ELK alarm with the module, I use ELK motion sensors to trigger ISY actions. I subscribe to ISY portal. Do I have options to get rid of the PLM?
  15. Not sure how to answer. I have an ISY99 with zwave module. I use a PLM. Program is in the ISY
