theedudenator
Everything posted by theedudenator
  1. I am a bit lost on how this is made, and how does it count? $iMotionCount < 5
  2. I have a motion on the back of my house that is running though my ELK M1 I have an ISY program to turn a light on when motion is sensed. The problem is the motion sensor seems too sensitive, not sure if bugs or birds are triggering it. Is there options in a program to sense multiple motion events with a time limit to trigger the lights?
  3. Only seeing one zwave device, but it doesn't have built in GFCI like the radiant floor manufacture wants. I am now thinking of just buying the cheap non-programable floor thermostat and using a higher amp zwave switch to stop/start the entire system. Any thoughts or suggestions?
  4. Should use Linux and deal with Java. I am to the point of looking for something aside from ISY cause of the use of unsupported Java Sent from my SM-G973U using Tapatalk
  5. Upgrade process is convoluted. No clue why it can't auto be done through the software... Sent from my SM-G973U using Tapatalk
  6. I ment EBAY!!! Paypal is fine. Sent from my SM-G973U using Tapatalk
  7. I have stuff I have swapped over the years, including a new PLM. Any place to sell this stuff? Been trying local, and won't use Paypal Sent from my SM-G973U using Tapatalk
  8. I bought the new 500 module and updated to 5.3.0. Now I have all this extra stuff, is it normal?
  9. I have 3 older Honeywells in our house, no issues.
  10. I can see my isy99 in the portal. When I try to do web access nothing happens. Loading config
  11. Exactly what happened to me multiple times. I have a new never used PLM I want to sell... Sent from my SM-G973U using Tapatalk
  12. I guess I dont. Just installed the zwave only firmware, now I need to replace 5 devices... Sent from my SM-G955U using Tapatalk
  13. I think I need the PLM for ELK integration.
  14. Every 8monts to a year I have a PLM failure.... 80% of my devices are zwave 20% are insteon I have ELK alarm with the module, I use ELK motion sensors to trigger ISY actions. I subscribe to ISY portal. Do I have options to get rid of the PLM?
  15. Not sure how to answer. I have an ISY99 with zwave module. I use a PLM. Program is in the ISY
  16. Fri 02/15/2019 05:27:29 AM : [Std-Direct Ack] 0F.F3.2B-->ISY/PLM Group=0, Max Hops=3, Hops Left=2 In my program that controls the lights I ran the "else" "then" statements. Most of the "hops left" was 3. Once I had a 2
  17. I have a scene with lights on it. Various Zwave and Insteon devices. The zwave devices always turn on/off. The insteon devices not always, some do all the time and some never do. If I control the insteon device or any other direct programs they work fine. So I don't think I have a communication issue. Any suggestions on why this happens? Do I need to remove insteon from the scene?
  18. ue 2017/02/28 04:00:00 PM System -140008 FYP:500 Tue 2017/02/28 04:01:00 PM System -140008 FYP:500 Tue 2017/02/28 04:02:00 PM System -140008 FYP:500 Tue 2017/02/28 04:03:01 PM System -140008 FYP:500 Tue 2017/02/28 04:16:00 PM System -140008 FYP:500 Tue 2017/02/28 04:22:34 PM System -50001 -19 Tue 2017/02/28 04:22:35 PM System -50001 -19 Tue 2017/02/28 04:22:37 PM System -50001 -19 Tue 2017/02/28 04:32:48 PM System -100 No network connection Tue 2017/02/28 04:33:03 PM System -170001 [Network] Established Tue 2017/02/28 05:06:04 PM System -50001 -19 Tue 2017/02/28 05:24:12 PM System -50001 -19 Tue 2017/02/28 05:33:51 PM System -100 No network connection Tue 2017/02/28 05:34:01 PM System -170001 [Network] Established Tue 2017/02/28 05:34:23 PM System -140000 my.isy.io Tue 2017/02/28 05:36:14 PM System -50001 -19 Tue 2017/02/28 05:44:32 PM System -50001 -19 Tue 2017/02/28 05:44:33 PM System -50001 -19 Tue 2017/02/28 05:44:34 PM System -50001 -19 Tue 2017/02/28 05:48:21 PM System -50001 -19 Tue 2017/02/28 06:33:06 PM System -50001 -19 Tue 2017/02/28 06:33:08 PM System -50001 -19 Tue 2017/02/28 06:33:09 PM System -50001 -19 Tue 2017/02/28 06:34:56 PM System -100 No network connection Tue 2017/02/28 06:35:11 PM System -170001 [Network] Established Tue 2017/02/28 07:36:06 PM System -100 No network connection Tue 2017/02/28 07:36:16 PM System -170001 [Network] Established Tue 2017/02/28 07:44:22 PM System -50001 -19 Tue 2017/02/28 07:44:23 PM System -50001 -19 Tue 2017/02/28 07:44:24 PM System -50001 -19 Tue 2017/02/28 08:37:10 PM System -100 No network connection Tue 2017/02/28 08:37:25 PM System -170001 [Network] Established Tue 2017/02/28 09:14:53 PM System -140000 flexyourpower.s3.amazonaws.com
  19. I have nothing X10. I do have Zwave and Insteon. So I think an iolink that I already own should be better? What about the trigger I shown?
  20. Both of our cars have the homelink buttons that are used to operate garage doors. I want to also program them to turn on lights. Something like this? Skylink 318TR And an Insteon or Zwave iolink would work? Then I would have an on/off signal I can use to trigger other events?
  21. Does this mean anything? I994 with latest firmware. Latest java in firefox
  22. The fifth time I tried it it worked...
  23. I followed the wiki I tried it again. When I go to admin screen Your System is in Safe Mode Restore PLM Modem Insteon_errors--30 -2000000/-30
  24. Had a power failure at the house. I guess this knocked the PDM out. The green light on the PDM would not turn on. Have the new one plugged in, it shows the green light. ISY 99 will not connect. When I start ADMIN it states "safe mode" When I "restore PDM" I get Error -20000----30
  25. I installed 3 Insteon and 3 Elk wireless motion sensors around my place. My lights have been acting funny the last few months, so I finally got around to logging into to ISY99. I wasn't getting any reaction from my Insteon motion sensors. I started to check batteries, all the Insteon 9v's were dead, ELK's still going strong. Shouldn't ISY tell me when the battery is getting low? Or is this something I need to program in? Thanks
