thewebgeek
  1. Wow that virtual node server is just what I was looking for! Thanks!
  2. Ok, we're making progress. I installed those packages, and re-installed the Vue node server. See below for the new errors from the log file. 023-01-13 17:06:10,904 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-01-13 17:06:11,314 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting... 2023-01-13 17:06:11,472 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-01-13 17:06:11,473 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/vue.py", line 10, in <module> 2023-01-13 17:06:11,473 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2023-01-13 17:06:11,473 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/__init__.py", line 2, in <module> 2023-01-13 17:06:11,473 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2023-01-13 17:06:11,473 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/pyemvue.py", line 10, in <module> 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: from warrant import Cognito 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/warrant/__init__.py", line 8, in <module> 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: from jose import jwt, JWTError 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/jose/jwt.py", line 11, in <module> 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: from jose import jws 2023-01-13 17:06:11,474 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/jose/jws.py", line 8, in <module> 2023-01-13 17:06:11,475 MainThread udi_interface ERROR udi_interface:write: from jose import jwk 2023-01-13 17:06:11,475 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/jose/jwk.py", line 10, in <module> 2023-01-13 17:06:11,475 MainThread udi_interface ERROR udi_interface:write: from jose.backends.base import Key 2023-01-13 17:06:11,475 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/jose/backends/__init__.py", line 3, in <module> 2023-01-13 17:06:11,475 MainThread udi_interface ERROR udi_interface:write: from jose.backends.pycrypto_backend import RSAKey 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/jose/backends/pycrypto_backend.py", line 7, in <module> 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: from Crypto.PublicKey import RSA 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/.local/lib/python3.9/site-packages/Crypto/PublicKey/RSA.py", line 137 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: e, d, n, p, q, u = [self._key[comp] for comp in 'e', 'd', 'n', 'p', 'q', 'u'] 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: ^ 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: SyntaxError 2023-01-13 17:06:11,476 MainThread udi_interface ERROR udi_interface:write: : 2023-01-13 17:06:11,477 MainThread udi_interface ERROR udi_interface:write: invalid syntax
  3. I have a few Homekit devices specifically for the Carplay integration, but I would like to fire events in IoX with them. I have the ability to control IoX devices based on Homekit events via the ISY plugin for Homebridge. I thought I was going to be able to use an empty scene for this, but you can't check the on/off status of a scene in a program. Is there a way to create a "virtual" switch device in IoX for this?
  4. Update - I tried installing the missing package, and made progress, but now something else is missing. sudo pkg install py39-boto3 - this fixed the missing boto3 module. See below for new missing item. I did some searching, but I'm not sure what package satisfies this one. 2023-01-13 15:57:00,630 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-01-13 15:57:01,035 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting... 2023-01-13 15:57:01,120 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-01-13 15:57:01,120 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/vue.py", line 10, in <module> 2023-01-13 15:57:01,120 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2023-01-13 15:57:01,120 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/__init__.py", line 2, in <module> 2023-01-13 15:57:01,120 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2023-01-13 15:57:01,121 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/pyemvue.py", line 10, in <module> 2023-01-13 15:57:01,121 MainThread udi_interface ERROR udi_interface:write: from warrant import Cognito 2023-01-13 15:57:01,121 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2023-01-13 15:57:01,121 MainThread udi_interface ERROR udi_interface:write: : 2023-01-13 15:57:01,121 MainThread udi_interface ERROR udi_interface:write: No module named 'warrant'
  5. Got the log (I'm an idiot, but thats a story for another day) Is there a way I can manually install the missing module on my ISY? 2023-01-13 15:33:29,570 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-01-13 15:33:29,975 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.0.51 Starting... 2023-01-13 15:33:29,976 MainThread udi_interface ERROR udi_interface:write: Traceback (most recent call last): 2023-01-13 15:33:29,976 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/vue.py", line 10, in <module> 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: import pyemvue 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/__init__.py", line 2, in <module> 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: from pyemvue.pyemvue import PyEmVue 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: File "/var/polyglot/pg3/ns/0021b9025f8a_3/pyemvue/pyemvue.py", line 8, in <module> 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: import boto3 2023-01-13 15:33:29,977 MainThread udi_interface ERROR udi_interface:write: ModuleNotFoundError 2023-01-13 15:33:29,978 MainThread udi_interface ERROR udi_interface:write: : 2023-01-13 15:33:29,978 MainThread udi_interface ERROR udi_interface:write: No module named 'boto3'
  6. No - it doesn't seem to be generating any logs.
  7. Other than the username and password configuration items, is there something else you need to configure to get the node server to start?
  8. I was able to SSH in and fix the IP address, but I'm still on 5.4.5. What are the plans on fixing the GUI for this?
  9. Just got the EISY setup and plugged in - I used the mobile app to find it and attach it to the portal. I see in the app that the local access is via http://eisy.local:8080 but when I try and connect, I just get a blank page. Is there some trick to connecting to the device once its setup in the portal for things like changing the IP address and setting up node servers?
  10. thewebgeek posted a topic in eisy
    I'm still using my trusty 2412S PLM with my 994 - will I be able to use it with the EISY + Serial kit?
  11. The temporary PG2 solution is in place and working! Thanks again for the help and I look forward to the EISY being released.
  12. It sounds like the RPi may be my best option until the Eisy is available, especially since I have one on hand. Are there any setup guides still available for PG2?
  13. How do you configure a node server on the ISY994 without Polyglot Cloud?
  14. With winter approaching, and Polyglot Cloud (PGC) still offline, does anyone have a workaround to bring in weather data to the ISY994? I migrated to Polyglot cloud after the built-in weather service was turned off, but with PGC offline, I am stuck. Any help is appreciated.
  15. With PGC unavailable for a bit while it is rebuilt, is there a way to run the Polyglot server in a virtual machine to bridge the gap until PGC is up and running again? I'm really conflicted about buying another piece of hardware (Polisy) that is only going to serve a temporary role.
