jon7889
Everything posted by jon7889
  1. Is there a way to "Replace" the motion sensors rather than remove and replace them? I'm concerned about things not functioning properly if I remove them and then forget what scenes they belong to and what programs they are used in. If not, is there a way to determine which program they are used in beyond just opening every single program and checking? I have 6 or 7 motion sensors, and I'm not sure I remember every program I've used them all in. It seems like a hassle - but if that's the only way, I'll do it. Just hoping there might be an easier method. Thanks, Jon
  2. I am using a Motion II Sensor which should be 2844-222, but it's listed as 2822-222
  3. This is what I have installed...
  4. I do have 5.3.3 running, but I don't see an option to change the device type or the sensitivity. This is all I see:
  5. I have several Insteon Motion II sensors. In the ISY, they are listed as 2842-222, but I believe the correct model number should be 2844-222. Everything works fine with them, EXCEPT I'd like to adjust the sensitivity on them and make them more sensitive. After looking through the forums, I believe there should be a sensitivity adjustment in the ISY Administrative Console, but there isn't. I'm thinking it may be because they have been set up as 2842-222 and not 2844-222. Is this correct? Or am I off? If so, is there some other reason why I can't control their sensitivities? Thanks, Jon
  6. I have several Insteon Motion II sensors. In the ISY, they are listed as 2842-222, but I believe the correct model number should be 2844-222. Everything works fine with them, EXCEPT I'd like to adjust the sensitivity on them and make them more sensitive. After looking through the forums, I believe there should be a sensitivity adjustment in the ISY Administrative Console, but there isn't. I'm thinking it may be because they have been set up as 2842-222 and not 2844-222. Is this correct? Or am I off? If so, is there some other reason why I can't control their sensitivities? Thanks, Jon
