WGKirby
  1. From Michael's comment to Stu's post, can someone explain what and Entry word is? Do you mean a word that symbolizes an entry into a house or is it something more programmatic? That statement seems to have more meaning than I am able to understand. I forgot the program "All Blinds" from the portal and recreated it. I added "all blinds" and "Blinds" to my spoken words. I rediscovered my devices and have the same issue. The spoken word Open "All Blinds" does not work where it had been working for months and the Spoken work Close "All Blinds" does still work. As I mentioned I added the spoken word "Blinds" to the ISY portal along with "all Blinds" and Open "Blinds" and Close "Blinds" works. I hate not knowing why something as simple as a "Turn on" substitute became so difficult.
  2. Hello, thanks for your response. I have been using v2 since it released I just never removed v1. When I talked to Alexa support they said the v2 offering did not offer the open command. Since open is working on some devices, just not the program I need, their statement did not make sense. Do you have any suggestions on what I can do to trouble shoot this problem. I really want to say open blinds instead of turn on blinds. Sent from my iPhone using Tapatalk
  3. I have had Alexa working with my ISY and Universal Portal for a very long time. I have been able to open my Somfy blinds using using a program I created called "All Blinds" The program opens the blinds on "on" and closes the blinds on "off". So I could say Alexa Open "All Blinds" and Alexa Close "All Blinds". Within the last few weeks I have not been able to get the Open command word to work. I can say Alexa turn on "All Blinds" and the blinds open and I can say Alexa Close "all Blinds" to close them. I do not know what has changed. Funny thing is I can tell alexa open "office light" and have my office light turn on so the open command is not completely non functional. I called Alexa support and they said that the ISY optimized for Smart Home V2 skill does not have a open command and that the original ISY skill V1 did. Did universal recently remove the V1 Skill? Is that why I started having problems with the Open command? If so why does the open command work on some devices at my house and not others? Any help is appreciated, Bill
  4. I think we have an answer. I did upgrade the ISY through the push update process and the screen did report all was well and running at 3.2.6 for both interface and firmware, but Michel was right, when I telneted int the box I recieved the following: Product: (1050) ISY 99i 1024 IR App: Insteon_UD99 Platform: ISY-C-99 Version: 3.1.17 Build Date: 2012-01-19-15:34:02 Other Services: - Programs Enabled - IR Enabled Modules: 21040 - Networking Module Since this version does not have i2cs support I think the problem has been identified. The question now is what is the best way to fix this. Should I download a beta and upgrade out of this issue or should I download 3.2.6 and re-apply. Your ideas would be appreciated.
  5. First of all I must apologize for this insanely long post. I tried a number of things tonight with no success. 1. I ran an extension cord from another circuit to the PLM to try to rule out line noise. I factory reset a switchlinc relay switch and linked it to the ISY using the automatic messaging option. I then ran diagnostics – show device links – and had incremental hex numbers in the listing (junk). 2. I installed my old 2412s PLM (works fine just not dual band) and re-ran the above test with the same results 3. I ran the above test steps and used advance option “Device reported messaging†option and had the same results. 4. I manually linked the switch link relay switch using the “New Insteon Device†and picked the 2476s switch and had the same results. I then ran the test in step 1 and captured a level 3 event log of the process. I am not skilled enough to recognize any problems in this capture, but I hope one of the learned people of this forum can see something useful. Thu 10/11/2012 10:55:03 PM : [LNK-BGN ] 02 64 01 00 06 Thu 10/11/2012 10:55:23 PM : [LNK-STAT ] 02 53 M(01) gid=00 1B.E1.15 021C 41 Thu 10/11/2012 10:55:23 PM : Linked: Linked 1B.E1.15.00 type=02.1C.41 Thu 10/11/2012 10:55:23 PM : [1B E1 15 1 ] Start : Adding device to ISY Thu 10/11/2012 10:55:24 PM : [1B E1 15 1 ] Finish : Adding device to ISY was Successful Thu 10/11/2012 10:55:24 PM : [All ] Writing 0 bytes to devices Thu 10/11/2012 10:55:24 PM : [LNK-BGN ] 02 64 01 00 06 Thu 10/11/2012 10:55:46 PM : ---- Initializing the linked devices ---- Thu 10/11/2012 10:55:46 PM : [ 1B E1 15 1] Writing High Water Mark at Link 0 Thu 10/11/2012 10:55:46 PM : [LNK-END ] 02 65 06 : : Unexpected, ignored (65) Thu 10/11/2012 10:55:46 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1' Thu 10/11/2012 10:55:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:47 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F8 06 PEEK (F8) Thu 10/11/2012 10:55:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F8 PEEK (F8) Thu 10/11/2012 10:55:47 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:55:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:55:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Link 0 : 0FF8 [A2001CFC58FF1F01] Saving [A2001CFC58FF1F01] Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Link 1 : 0FF0 [E2011CFC58FF1F01] Saving [E2011CFC58FF1F01] Thu 10/11/2012 10:55:48 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1' Thu 10/11/2012 10:55:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 00 06 SET-MSB(00) Thu 10/11/2012 10:55:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 00 SET-MSB(00) Thu 10/11/2012 10:55:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 32 06 PEEK (32) Thu 10/11/2012 10:55:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 32 PEEK (32) Thu 10/11/2012 10:55:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 00 06 SET-MSB(00) Thu 10/11/2012 10:55:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 00 SET-MSB(00) Thu 10/11/2012 10:55:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 21 06 PEEK (21) Thu 10/11/2012 10:55:50 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 21 PEEK (21) Thu 10/11/2012 10:55:50 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:50 PM : [FileOpen ] Open failed for [/LOG/A.LOG] (a) Thu 10/11/2012 10:55:50 PM : ---- All Linked Devices are now initialized ---- Thu 10/11/2012 10:55:50 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 19 00 06 LTSREQ (LIGHT) Thu 10/11/2012 10:55:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 02 FF (FF) Thu 10/11/2012 10:55:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:51 PM : ---- Initializing the linked devices ---- Thu 10/11/2012 10:55:51 PM : ---- All Linked Devices are now initialized ---- Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] OL 50 Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] RR 33 Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] ST 255 Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] OL 50 Thu 10/11/2012 10:55:51 PM : [ 1B E1 15 1] RR 33 Thu 10/11/2012 10:55:51 PM : [All ] Writing 16 bytes to devices Thu 10/11/2012 10:55:51 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1' Thu 10/11/2012 10:55:51 PM : [1B E1 15 1 ] Link 2 : 0FE8 [0000000000000000] Writing [00..............] Thu 10/11/2012 10:55:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B E8 06 PEEK (E8) Thu 10/11/2012 10:55:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B E8 PEEK (E8) Thu 10/11/2012 10:55:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:55:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:55:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:52 PM : [1B E1 15 1 ] Link 3 : 0FE0 : Writing High Water Byte Thu 10/11/2012 10:55:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B E0 06 PEEK (E0) Thu 10/11/2012 10:55:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B E0 PEEK (E0) Thu 10/11/2012 10:55:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:55:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:55:54 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:54 PM : [1B E1 15 1 ] Link 4 : 0FD8 : Writing High Water Byte Thu 10/11/2012 10:55:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:54 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B D8 06 PEEK (D8) Thu 10/11/2012 10:55:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B D8 PEEK (D8) Thu 10/11/2012 10:55:55 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:55 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:55:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:55:55 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:55 PM : [1B E1 15 1 ] Link 5 : 0FD0 : Writing High Water Byte Thu 10/11/2012 10:55:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:56 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B D0 06 PEEK (D0) Thu 10/11/2012 10:55:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B D0 PEEK (D0) Thu 10/11/2012 10:55:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:55:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:55:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:58 PM : [1B E1 15 1 ] Link 6 : 0FC8 : Writing High Water Byte Thu 10/11/2012 10:55:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:55:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:55:59 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B C8 06 PEEK (C8) Thu 10/11/2012 10:55:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B C8 PEEK (C8) Thu 10/11/2012 10:55:59 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:55:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:00 PM : [1B E1 15 1 ] Link 7 : 0FC0 : Writing High Water Byte Thu 10/11/2012 10:56:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B C0 06 PEEK (C0) Thu 10/11/2012 10:56:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B C0 PEEK (C0) Thu 10/11/2012 10:56:01 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:02 PM : [1B E1 15 1 ] Link 8 : 0FB8 : Writing High Water Byte Thu 10/11/2012 10:56:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B B8 06 PEEK (B8) Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 23.71.15 1C.FC.58 23 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][23.71.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 23.71.15 1C.FC.58 23 28 0F SET-MSB(0F): Process Message: Ignored Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][23.71.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Thu 10/11/2012 10:56:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Thu 10/11/2012 10:56:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B B8 PEEK (B8) Thu 10/11/2012 10:56:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:04 PM : [1B E1 15 1 ] Link 9 : 0FB0 : Writing High Water Byte Thu 10/11/2012 10:56:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B B0 06 PEEK (B0) Thu 10/11/2012 10:56:05 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B B0 PEEK (B0) Thu 10/11/2012 10:56:05 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:05 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:06 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:06 PM : [1B E1 15 1 ] Link 10 : 0FA8 : Writing High Water Byte Thu 10/11/2012 10:56:06 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:07 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:07 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:07 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B A8 06 PEEK (A8) Thu 10/11/2012 10:56:07 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B A8 PEEK (A8) Thu 10/11/2012 10:56:07 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:08 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:08 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:08 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:08 PM : [1B E1 15 1 ] Link 11 : 0FA0 : Writing High Water Byte Thu 10/11/2012 10:56:08 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:08 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:08 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:09 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B A0 06 PEEK (A0) Thu 10/11/2012 10:56:09 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B A0 PEEK (A0) Thu 10/11/2012 10:56:09 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:09 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:09 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:09 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:09 PM : [1B E1 15 1 ] Link 12 : 0F98 : Writing High Water Byte Thu 10/11/2012 10:56:10 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:10 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:10 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:10 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 98 06 PEEK (98) Thu 10/11/2012 10:56:11 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 98 PEEK (98) Thu 10/11/2012 10:56:11 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:11 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:12 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:12 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:12 PM : [1B E1 15 1 ] Link 13 : 0F90 : Writing High Water Byte Thu 10/11/2012 10:56:12 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:12 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:12 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:12 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 90 06 PEEK (90) Thu 10/11/2012 10:56:13 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 90 PEEK (90) Thu 10/11/2012 10:56:13 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:13 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:13 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:13 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:13 PM : [1B E1 15 1 ] Link 14 : 0F88 : Writing High Water Byte Thu 10/11/2012 10:56:13 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:14 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:14 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:14 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 88 06 PEEK (88) Thu 10/11/2012 10:56:14 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 88 PEEK (88) Thu 10/11/2012 10:56:14 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:14 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:15 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:15 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:15 PM : [1B E1 15 1 ] Link 15 : 0F80 : Writing High Water Byte Thu 10/11/2012 10:56:15 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:15 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:15 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:15 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 80 06 PEEK (80) Thu 10/11/2012 10:56:16 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 80 PEEK (80) Thu 10/11/2012 10:56:16 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:16 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:17 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:17 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:17 PM : [1B E1 15 1 ] Link 16 : 0F78 : Writing High Water Byte Thu 10/11/2012 10:56:17 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:17 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:17 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:17 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 78 06 PEEK (78) Thu 10/11/2012 10:56:18 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 78 PEEK (78) Thu 10/11/2012 10:56:18 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:18 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:18 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:18 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:18 PM : [1B E1 15 1 ] Link 17 : 0F70 : Writing High Water Byte Thu 10/11/2012 10:56:18 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:19 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:19 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:19 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 70 06 PEEK (70) Thu 10/11/2012 10:56:19 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 70 PEEK (70) Thu 10/11/2012 10:56:19 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:19 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:20 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:20 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:20 PM : [1B E1 15 1 ] Link 18 : 0F68 : Writing High Water Byte Thu 10/11/2012 10:56:20 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:21 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:21 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:21 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 68 06 PEEK (68) Thu 10/11/2012 10:56:22 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 68 PEEK (68) Thu 10/11/2012 10:56:22 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:22 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:22 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:22 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:22 PM : [1B E1 15 1 ] Link 19 : 0F60 : Writing High Water Byte Thu 10/11/2012 10:56:22 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:23 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:23 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:23 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 60 06 PEEK (60) Thu 10/11/2012 10:56:23 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 60 PEEK (60) Thu 10/11/2012 10:56:23 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:23 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:25 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:25 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:25 PM : [1B E1 15 1 ] Link 20 : 0F58 : Writing High Water Byte Thu 10/11/2012 10:56:25 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:25 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:25 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:25 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 58 06 PEEK (58) Thu 10/11/2012 10:56:26 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 58 PEEK (58) Thu 10/11/2012 10:56:26 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:26 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:27 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:27 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:27 PM : [1B E1 15 1 ] Link 21 : 0F50 : Writing High Water Byte Thu 10/11/2012 10:56:27 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:27 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:27 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:27 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 50 06 PEEK (50) Thu 10/11/2012 10:56:28 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 50 PEEK (50) Thu 10/11/2012 10:56:28 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:28 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:29 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:29 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:29 PM : [1B E1 15 1 ] Link 22 : 0F48 : Writing High Water Byte Thu 10/11/2012 10:56:29 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:29 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:29 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:29 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 48 06 PEEK (48) Thu 10/11/2012 10:56:30 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 48 PEEK (48) Thu 10/11/2012 10:56:30 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:30 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:30 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:30 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:30 PM : [1B E1 15 1 ] Link 23 : 0F40 : Writing High Water Byte Thu 10/11/2012 10:56:30 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:32 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:32 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 40 06 PEEK (40) Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 40 PEEK (40) Thu 10/11/2012 10:56:32 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:32 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:32 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:32 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:32 PM : [1B E1 15 1 ] Link 24 : 0F38 : Writing High Water Byte Thu 10/11/2012 10:56:33 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:33 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:33 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:33 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 38 06 PEEK (38) Thu 10/11/2012 10:56:34 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 38 PEEK (38) Thu 10/11/2012 10:56:34 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:34 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:34 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:34 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:34 PM : [1B E1 15 1 ] Link 25 : 0F30 : Writing High Water Byte Thu 10/11/2012 10:56:34 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:35 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:35 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:35 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 30 06 PEEK (30) Thu 10/11/2012 10:56:35 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 30 PEEK (30) Thu 10/11/2012 10:56:35 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:35 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:36 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:36 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:36 PM : [1B E1 15 1 ] Link 26 : 0F28 : Writing High Water Byte Thu 10/11/2012 10:56:36 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:36 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:36 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:37 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 28 06 PEEK (28) Thu 10/11/2012 10:56:37 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 28 PEEK (28) Thu 10/11/2012 10:56:37 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:37 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:37 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:37 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:37 PM : [1B E1 15 1 ] Link 27 : 0F20 : Writing High Water Byte Thu 10/11/2012 10:56:38 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:38 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:38 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:38 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 20 06 PEEK (20) Thu 10/11/2012 10:56:39 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 20 PEEK (20) Thu 10/11/2012 10:56:39 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:39 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:39 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:39 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:39 PM : [1B E1 15 1 ] Link 28 : 0F18 : Writing High Water Byte Thu 10/11/2012 10:56:39 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:40 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:40 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:40 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 18 06 PEEK (18) Thu 10/11/2012 10:56:40 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 18 PEEK (18) Thu 10/11/2012 10:56:40 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:41 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:41 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:41 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:41 PM : [1B E1 15 1 ] Link 29 : 0F10 : Writing High Water Byte Thu 10/11/2012 10:56:41 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:41 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:41 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:42 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 10 06 PEEK (10) Thu 10/11/2012 10:56:42 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 10 PEEK (10) Thu 10/11/2012 10:56:42 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:42 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:43 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:43 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:43 PM : [1B E1 15 1 ] Link 30 : 0F08 : Writing High Water Byte Thu 10/11/2012 10:56:43 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:43 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:43 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:43 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 08 06 PEEK (08) Thu 10/11/2012 10:56:44 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 08 PEEK (08) Thu 10/11/2012 10:56:44 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:44 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:45 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:45 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:45 PM : [1B E1 15 1 ] Link 31 : 0F00 : Writing High Water Byte Thu 10/11/2012 10:56:45 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:45 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:45 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:45 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B 00 06 PEEK (00) Thu 10/11/2012 10:56:46 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B 00 PEEK (00) Thu 10/11/2012 10:56:46 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:46 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1' Thu 10/11/2012 10:56:46 PM : [1B E1 15 1 ] Link 0 : 0FF8 [A2001CFC58FF1F01] Writing [A2001CFC58FF1F01] Thu 10/11/2012 10:56:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:46 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:46 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:46 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F8 06 PEEK (F8) Thu 10/11/2012 10:56:47 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F8 PEEK (F8) Thu 10/11/2012 10:56:47 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:47 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 A2 06 POKE (A2) Thu 10/11/2012 10:56:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 A2 POKE (A2) Thu 10/11/2012 10:56:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F9 06 PEEK (F9) Thu 10/11/2012 10:56:48 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F9 PEEK (F9) Thu 10/11/2012 10:56:48 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:48 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 00 06 POKE (00) Thu 10/11/2012 10:56:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 00 POKE (00) Thu 10/11/2012 10:56:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FA 06 PEEK (FA) Thu 10/11/2012 10:56:49 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FA PEEK (FA) Thu 10/11/2012 10:56:49 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:49 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1C 06 POKE (1C) Thu 10/11/2012 10:56:50 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1C POKE (1C) Thu 10/11/2012 10:56:50 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:50 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FB 06 PEEK (FB) Thu 10/11/2012 10:56:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FB PEEK (FB) Thu 10/11/2012 10:56:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FC 06 POKE (FC) Thu 10/11/2012 10:56:51 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FC POKE (FC) Thu 10/11/2012 10:56:51 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:51 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FC 06 PEEK (FC) Thu 10/11/2012 10:56:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FC PEEK (FC) Thu 10/11/2012 10:56:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 58 06 POKE (58) Thu 10/11/2012 10:56:52 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 58 POKE (58) Thu 10/11/2012 10:56:52 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:52 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FD 06 PEEK (FD) Thu 10/11/2012 10:56:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FD PEEK (FD) Thu 10/11/2012 10:56:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FF 06 POKE (FF) Thu 10/11/2012 10:56:53 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FF POKE (FF) Thu 10/11/2012 10:56:53 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:53 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FE 06 PEEK (FE) Thu 10/11/2012 10:56:54 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FE PEEK (FE) Thu 10/11/2012 10:56:54 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:54 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1F 06 POKE (1F) Thu 10/11/2012 10:56:55 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1F POKE (1F) Thu 10/11/2012 10:56:55 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:55 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B FF 06 PEEK (FF) Thu 10/11/2012 10:56:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B FF PEEK (FF) Thu 10/11/2012 10:56:56 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:56 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01) Thu 10/11/2012 10:56:56 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01) Thu 10/11/2012 10:56:56 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:56 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1B E1 15 02 1C 41 06 Thu 10/11/2012 10:56:56 PM : [PLM ] Group 0 : Writing Controller Link matching [1B E1 15 1 ] Link 0 : FF8 [A2001CFC58FF1F01] Thu 10/11/2012 10:56:56 PM : [1B E1 15 1 ] Using engine version i1 for '1B.E1.15.1' Thu 10/11/2012 10:56:56 PM : [1B E1 15 1 ] Link 1 : 0FF0 [E2011CFC58FF1F01] Writing [E2011CFC58FF1F01] Thu 10/11/2012 10:56:57 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 28 0F 06 SET-MSB(0F) Thu 10/11/2012 10:56:57 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 28 0F SET-MSB(0F) Thu 10/11/2012 10:56:57 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:57 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F0 06 PEEK (F0) Thu 10/11/2012 10:56:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F0 PEEK (F0) Thu 10/11/2012 10:56:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 E2 06 POKE (E2) Thu 10/11/2012 10:56:58 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 E2 POKE (E2) Thu 10/11/2012 10:56:58 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:58 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F1 06 PEEK (F1) Thu 10/11/2012 10:56:59 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F1 PEEK (F1) Thu 10/11/2012 10:56:59 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:56:59 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01) Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01) Thu 10/11/2012 10:57:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F2 06 PEEK (F2) Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F2 PEEK (F2) Thu 10/11/2012 10:57:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:00 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1C 06 POKE (1C) Thu 10/11/2012 10:57:00 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1C POKE (1C) Thu 10/11/2012 10:57:00 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F3 06 PEEK (F3) Thu 10/11/2012 10:57:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F3 PEEK (F3) Thu 10/11/2012 10:57:01 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:01 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FC 06 POKE (FC) Thu 10/11/2012 10:57:01 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FC POKE (FC) Thu 10/11/2012 10:57:01 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F4 06 PEEK (F4) Thu 10/11/2012 10:57:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F4 PEEK (F4) Thu 10/11/2012 10:57:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:02 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 58 06 POKE (58) Thu 10/11/2012 10:57:02 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 58 POKE (58) Thu 10/11/2012 10:57:02 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 29 58 POKE (58) Thu 10/11/2012 10:57:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Thu 10/11/2012 10:57:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F5 06 PEEK (F5) Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F5 PEEK (F5) Thu 10/11/2012 10:57:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:03 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 FF 06 POKE (FF) Thu 10/11/2012 10:57:03 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 FF POKE (FF) Thu 10/11/2012 10:57:03 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 23 29 FF POKE (FF) Thu 10/11/2012 10:57:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=0 Thu 10/11/2012 10:57:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F6 06 PEEK (F6) Thu 10/11/2012 10:57:04 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F6 PEEK (F6) Thu 10/11/2012 10:57:04 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:04 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 1F 06 POKE (1F) Thu 10/11/2012 10:57:05 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 1F POKE (1F) Thu 10/11/2012 10:57:05 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:05 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 2B F7 06 PEEK (F7) Thu 10/11/2012 10:57:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 2B F7 PEEK (F7) Thu 10/11/2012 10:57:06 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:06 PM : [iNST-ACK ] 02 62 1B.E1.15 0F 29 01 06 POKE (01) Thu 10/11/2012 10:57:06 PM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 27 29 01 POKE (01) Thu 10/11/2012 10:57:06 PM : [standard-Direct Ack][1B.E1.15-->ISY/PLM Group=0] Max Hops=3, Hops Left=1 Thu 10/11/2012 10:57:06 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1B E1 15 02 1C 41 15 Thu 10/11/2012 10:57:06 PM : [PLM ] Group 1 : Writing Responder Link matching [1B E1 15 1 ] Link 1 : 0FF0 E2011CFC58FF1F01] Thu 10/11/2012 10:57:06 PM : [All ] Writing 0 bytes to devices
  6. I will re-link some of my problems switches and capture the level 3 event entries later tonight. I do have an interesting list of switch models by good or bad link tables. Bad means when I do a diagnostic - show device link table I get incremental hex numbers and no valid entrees. Except for 1 older appliance linc, none of my switchlinc switches have good link tables. Maybe someone can see a pattern here that will help. 2476s bad 2477s bad 2486d bad 2486d bad 2477s bad 2477s bad 2476s bad b2457d2 bad 2476s bad 2476s bad 2456s3 good 2477d good 2477d good 2476d good 2477d good 2477d good 2486d good 2477d good 2477d good 2477d good
  7. All my insteon switches were added under 3.2.6. I am converting from x10 for the ease of use an reliability Interesting, if I try to quey the Insteon engine I either get a "Request failed" dialog box or nothing at all. What is the Insteon engine?
  8. To update on existing questions. The UI and the firmware are both at 3.2.6 rev. Under the (Link Managment) (advanced Options) the advanced option is selected. I am now polling all of my devices to find out which ones have bad links. When the table is wrong it is just full of sequential hex numbers a1,a2,a3..... If this was noise would it not be more random?
  9. My software version on the ISY is 3.2.6 . The way I linked all my switches is by menu option (link Management) (Start Linking) with the remove existing links option selected. I have Factory reset the switches(2476s & 2477s) in one of my bad scenes a couple of times and deleted the switches from ISY and re-linked. Bad links still show up in the link table. I was able to locally link the two switches together (Smarthome way) and the switches would respond to on off command from each other. I could also still control both switches (individually) from the ISY. Unless anyone has any better suggestions I think tomorrow I will remove two known working switches and replace the problematic switches. Then if needed I might run an extension cord from another outlet and plug the PLM into that. The only other option is that I received 4 bad switches from Smarthome which is highly unlikely. Still seeking better options.
  10. Here is the device links table for the load switch in the Switchlinc relay scene that is not working. Device Links Table : Mud Room 1 / 1B E1 15 1 4088 248 249 16448508 16645887 Device Links Table : Mud Room 1 / 1B E1 15 1 4080 240 241 15922164 16119543 Device Links Table : Mud Room 1 / 1B E1 15 1 4072 232 233 15395820 15593199 Device Links Table : Mud Room 1 / 1B E1 15 1 4064 224 225 14869476 15066855 Device Links Table : Mud Room 1 / 1B E1 15 1 4056 216 217 14343132 14540511 Device Links Table : Mud Room 1 / 1B E1 15 1 4048 208 209 13816788 14014167 Device Links Table : Mud Room 1 / 1B E1 15 1 4040 200 201 13290444 13487823 Device Links Table : Mud Room 1 / 1B E1 15 1 4032 192 193 12764100 12961479 Device Links Table : Mud Room 1 / 1B E1 15 1 4024 184 185 12237756 12435135 Device Links Table : Mud Room 1 / 1B E1 15 1 4016 176 177 11711412 11908791 Device Links Table : Mud Room 1 / 1B E1 15 1 4008 168 169 11185068 11382447 Device Links Table : Mud Room 1 / 1B E1 15 1 4000 160 161 10658724 10856103 Device Links Table : Mud Room 1 / 1B E1 15 1 3992 152 153 10132380 10329759 Device Links Table : Mud Room 1 / 1B E1 15 1 3984 144 145 9606036 9803415 Device Links Table : Mud Room 1 / 1B E1 15 1 3976 136 137 9079692 9277071 Device Links Table : Mud Room 1 / 1B E1 15 1 3968 128 129 8553348 8750727 Device Links Table : Mud Room 1 / 1B E1 15 1 3960 120 121 8027004 8224383 Device Links Table : Mud Room 1 / 1B E1 15 1 3952 112 113 7500660 7698039 Device Links Table : Mud Room 1 / 1B E1 15 1 3944 104 105 6974316 7171695 Device Links Table : Mud Room 1 / 1B E1 15 1 3936 96 97 6447972 6645351 Device Links Table : Mud Room 1 / 1B E1 15 1 3928 88 89 5921628 6119007 Device Links Table : Mud Room 1 / 1B E1 15 1 3920 80 81 5395284 5592663 Device Links Table : Mud Room 1 / 1B E1 15 1 3912 72 73 4868940 5066319 Device Links Table : Mud Room 1 / 1B E1 15 1 3904 64 65 4342596 4539975 Device Links Table : Mud Room 1 / 1B E1 15 1 3896 56 57 3816252 4013631 Device Links Table : Mud Room 1 / 1B E1 15 1 3888 48 49 3289908 3487287 Device Links Table : Mud Room 1 / 1B E1 15 1 3880 40 41 2763564 2960943 Device Links Table : Mud Room 1 / 1B E1 15 1 3872 32 33 2237220 2434599 Device Links Table : Mud Room 1 / 1B E1 15 1 3864 24 25 1710876 1908255 Device Links Table : Mud Room 1 / 1B E1 15 1 3856 16 17 1184532 1381911 Device Links Table : Mud Room 1 / 1B E1 15 1 3848 8 9 658188 855567 Device Links Table : Mud Room 1 / 1B E1 15 1 3840 0 1 131844 329223 title ad fl gr id data ISY Links Table : Mud Room 1 / 1B E1 15 1 4088 162 0 1899608 16719617 ISY Links Table : Mud Room 1 / 1B E1 15 1 4080 162 1 2026957 16719617 ISY Links Table : Mud Room 1 / 1B E1 15 1 4072 162 17 1899608 16719617 ISY Links Table : Mud Room 1 / 1B E1 15 1 4064 226 1 1899608 16719617 ISY Links Table : Mud Room 1 / 1B E1 15 1 4056 226 1 2026957 16719617
  11. I think you are on to something. When I performed the diagnostic show device links on any switch in a scene that was not working, I recieved a lot of junk links. If you can tell me an easy to read way to post the xml file I will. The switch links table had 31 entries 5 of which were "record mismatch" and the rest were "extra records". All of the entries were just hex entries starting with 00 and going up. Another strange thing was that the ISY progress bar acutally went from 0%-100% twice for each bad scene switch and once for all other switches. The ISY table had 5 entries. How did this happen and how do I fix this?
  12. I have two scenes that are failing. 1. Has two switchlinc relay switches one of which controls the fluorescent tube fixture that cannot be changed. This is the same scene that I sent the scene diagnostic information on above. 2. Is a scene that has two switchlinc 6 button dimmers with incandescent loads attached to each switch. The PLM is plugged into a circuit with other AV gear. I do have a filter and a filtering power strip between the PLM and these devices. I can control each switch independently with complete success. With both of these scenes I can go to each switch device and turn it on and off from the ISY and watch the physical switch turn on and off and also see the ISY device show the switch turn on and off. It is only when I try to control the switches with scenes that if have failures. I woul think that if I can control the individual switches communication "should not" be an issue. I am confused. I thought that insteon had a durable communication scheme, meaning that if you told a switch to turn on you would receive a confirmation from the switch stating the switch turned on. When I tell my misbehaving scenes to turn on why does the ISY show that the switches turned on when the physical switches did not change. Is the ISY just assuming the switches turned on and not listening for the response?
  13. The fluoesent lights controlled by the relay switches are tube. I rebooted the ISY and was able to run a scene test. results below. Wed 10/10/2012 10:59:48 AM : [GRP-RX ] 02 61 11 13 00 06 Wed 10/10/2012 10:59:48 AM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 E1 13 FF LTOFFRR(FF) Wed 10/10/2012 10:59:49 AM : [iNST-SRX ] 02 50 1E.ED.CD 1C.FC.58 E1 13 FF LTOFFRR(FF) Wed 10/10/2012 10:59:49 AM : [iNST-SRX ] 02 50 1B.E1.15 1C.FC.58 E1 13 FF LTOFFRR(FF) Wed 10/10/2012 10:59:49 AM : [CLEAN-UP-RPT] 02 58 06 Wed 10/10/2012 10:59:49 AM : [iNST-SRX ] 02 50 1E.ED.CD 1C.FC.58 E1 13 FF LTOFFRR(FF) >----- Laundry Room Test Results ----- [Failed] Mud Room 1 (1B E1 15 1) [Failed] Mud Room 2 (1E ED CD 1) >----- Laundry Room Test Results ----- Wed 10/10/2012 10:59:56 AM : [iNST-ACK ] 02 62 00.00.11 CF 13 00 06 LTOFFRR(00)
  14. Thanks for the reply. The load for the (2) 6 button switchlinc switches is incandescent. The Load for the (2) switchlinc relay switches is fluoresent. I have multiple ( dual band devices providing bridging across phases. I can controll each switch in each of the scenes that does not work individually with 100% success. When I tried to run a scene test nothing happened. I was not presented with a list of scenes..... nothing happened. Below is a log of me turning on and off a scene that does not work. Wed 10/10/2012 09:13:08 AM : [iNST-ACK ] 02 62 00.00.11 CF 11 00 06 LTONRR (00) Wed 10/10/2012 09:13:08 AM : [ 1B E1 15 1] ST 255 Wed 10/10/2012 09:13:08 AM : [ 1E ED CD 1] ST 255 Wed 10/10/2012 09:13:13 AM : [iNST-ACK ] 02 62 00.00.11 CF 13 00 06 LTOFFRR(00) Wed 10/10/2012 09:13:13 AM : [ 1B E1 15 1] ST 0 Wed 10/10/2012 09:13:13 AM : [ 1E ED CD 1] ST 0
  15. I have created 4 scenes of which 2 work properly and 2 do not. All individual switches can be controlled from the ISY device screen with 100 % accuracy. The scenes that work are as follows: 2 switchlinc dimmers in a logical 3way 3 switchlinc dimmers in a logical 4way The scenes that do not work are as follows: 2 switchlinc relays in a logical 3way 2 switchlinc 6 button in a logical 3way. In the ISY administration console I can go to the scene and send an on and off command and the scene status indicator shows both switches changing state from on to off with no change to the loads actual status (light does not go on or off). If I go to the individual devices that make up the scene and look at their status they report consistent with the scene status. If I go to the switch controlling the load and the switch is reporting it is off I can turn the switch on and the load turns on. If I go to the switch controlling the load and it was turned on by a scene command (light is not on but is reporting on) and I turn the switch device off then back on the light will turn on. If i physically try to control the load from switch in a scene that is not controlling the load I can not. All switches are set as controllers in each scene. I can not figure out why two scenes work and two do not. Any help on trouble shooting this would be appreciated.
