Steve L
  1. Yes, Zmatter. This XML file does not appear to have any style information associated with it. The document tree is shown below. <RestResponse succeeded="true"> <status>200</status> </RestResponse> But it worked! The delete worked too, though I saw nothing in the event log (I tested the lock, and the code was no longer recognized.) Thanks - I look forward to seeing this in UD Mobile.
  2. I tried it but it didn't work. I got a blank page from the URL - no indication that it sent a request other than the blank page has a title of eisy-ui. The event log shows nothing, even at level 3. The lock does not recognize the code. The URL I used was https://my.isy.io/isy/<long-hex-string>/zwave/node/ZY071_1/security/user/4/set/code/3511 where ZY071_1 is the lock.
  3. This is for the web UI, right? Still not something I can do remotely. Will it also be coming to UD Mobile?
  4. It's going on four years now since I submitted a Github request to include management of user key codes for Z-Wave locks in UD Mobile. At present, the only way to do this is in the Java admin panel, which makes it inaccessible to mobile devices, and even there it's not the most user friendly. The new web UI doesn't have it either, last I checked. Should I assume that no movement on this loss of functionality in four years means I should give up and seek an alternative outside of the UD ecosystem? I started to explore Home Assistant, and while support there does exist, I have not been able to make it work yet (instructions are opaque.)
  5. Wrong link for release post.
  6. Coming back to this. I now have Home Assistant with its UD integration. Unfortunately, all the solutions I can find to manage the lock assume I am using a USB Z-wave stick connected to the HA host (I am using a Home Assistant Green box). I have read that one can install HA on the EISY - if I do, will HA treat the UD Z-wave adapter as a USB adapter? Or do I just move the lock to the HA box (I do have a Zooz USB adapter) and forget about the UD integration? This is all so complicated when all I really wanted was for UD Mobile to be able to manage the lock codes. I keep reading that there is a plan to replace the Java UD console, but I worry that the replacement won't support managing Z-Wave lock users.
  7. I decided to give Home Assistant a try - I've been thinking about it for a while and this pushed me over the edge.
  8. Just keep in mind that UD Mobile still does not provide support for managing lock users, which the Java console has, and which I consider critical functionality. I submitted a feature request for this a couple of years ago.
  9. Thanks - for some reason, search is not working for me - any search returns zero results. Hmm.
  10. Huh - a forum search for ZSE70 came up empty, hence my post. Got a link to the other mentions?
  11. Has anyone tried the new Zooz ZSE70 outdoor motion sensor, a replacement for the ZSE29? Does the EISY understand it?
  12. My case, at least, was self-inflicted by not carefully reading the instructions. The lock has a central round "Program" button, and two other buttons generally labeled A and B in the instructions. I had been pressing the Program button when adding the lock, but this was incorrect - I should instead have pushed the A button (upper left corner) as directed in the instructions. When I did this, all the nodes got properly added. One does need to clean out the old nodes first. Since this was my second lock, I assumed I knew what to do, but it had been two years and you know what they say about "assume".
  13. No, it is Zwave. Baldwin doesn't offer a Zigbee version.
  14. Baldwin 8235003ZW. It is electronically the same as the Kwikset 916.
  15. EISY 5.8.4 (firmware and UI). I put the lock inches away from the EISY and tried again, same result.
