60Driver
  1. I got feed back from Jasco today that the switches should be showing as controllers. They said contact Universal Devices
  2. Sorry, poor spelling. Firmware is 5.2.0
  3. The file "Start.jnlp" came from the link you posted. It downloaded to computer and I executed it. Firm where is 5.2.0
  4. They are zwave plus devices and there status changes immediately when manually activated.
  5. I have added 42 of the Jasco ZW3005 Dimmers and 11 ZW4005 switches to the ISY. The ZW4005s all show as controllers. The ZW3005s all show as receivers. Looking at the ZWave Alliance website I found the below supported classes for the ZW3005 and ZW4005 (pasted below). They appear to be the same. Can anyone tell me why the ZW3005 can't be a controller? I envisioned using tablets mounted to the walls as scene controllers but I haven't found a way to do create scenes without a switch acting as the controller. If the ZW3005 can't be a controller is there away to create a virtual controller for the scenes? Model: In-Wall Smart Dimmer (14321/ZW3005) Z-Wave Certification Number: ZC10-16125367 Supported Command Classes Association Group Info Association V2 Basic Configuration CRC16 Encapsulation Device Reset Locally Firmware Update Meta-Data V2 Manufacturer Specific V2 Powerlevel Scene Activation Scene Actuator Conf Switch All Switch Multilevel V2 Version V2 Z-Wave Plus Info V2 Controlled Command Classes Basic Model: In-Wall Switch (39455 / ZW4005) Z-Wave Certification Number: ZC10-19126816 Supported Command Classes Association Group Info Association V2 Basic Configuration CRC16 Encapsulation Device Reset Locally Firmware Update Meta-Data V2 Manufacturer Specific V2 Powerlevel Scene Activation Scene Actuator Conf Switch All Switch Binary Version V2 Z-Wave Plus Info V2 Controlled Command Classes Basic
  6. I went through this. However, it starts out with setting path to JDK not JRE. I have a JRE directory. I subtended JRE for JDK and followed the procedure but had no effect. I cleared the cache and application and ran the start.exe again. The ISY Finder starts on it's own as part of install but once closed activating the desktop link results in the same message.
  7. I followed Techman's advise. The app started. I closed the app and tried to open it again and got the "Cannot determine java home" message again. But I can launch the app from the Java cash viewer page.
  8. Sorry. I did miss your question. It is Version 8 Update 301 (build 1.8.0_301-b09). Yes it came from the official Java website. Running on Windows 10 version 20H2
  9. As I said in the first paragraph of my post. I get the error message when I try to run from the app icon.
  10. 60Driver joined the community
  11. I followed the instructions in the first post. The ISY Launcher app was created on my desktop. However, when the app is initiated a window pops up with "Cannot determine a valid Java Home". The header on the pop up window is: Java(TM) Web Start 11.171.2.11-fcs. I can start the ISY Finder by selecting from the Java control panel General->Temporary Internet Files->view and running the ISY Launcher. Then I can right click on the link in the ISY Finder to launch the administrative console. Clearly there should be an easier way. I repeated the installation process multiple times and each time the ISY Launcher started with the same message.
