JEllin
Everything posted by JEllin
  1. Well, I removed the device from ISY and re-added it, This time I ended up with 4 nodes. ZW006 WALL CONTROLLER ZW006 SCENE BUTTON 1 ZW006 SCENE BUTTON 2 ZW006 SCENE CONTROL 2 ZW 006 Multilevel Switch 3 Interestingly the ZW006 SCENE CONTROL 2 has a status that appears have values of either 0 or 256. Which I can respond to in a program, I have no idea what the other 4 or four, or how to activate the double tap scenes that the controller supports.
  2. I don't see anything but the one node ZW_006WallController, I tried using the Responding True/False in a Program to see if I could get it to do anything, nope. :(.
  3. Hello All, I just picked up a Zooz Zen34 Scene controller. I was able to get it included in the network with the ISY, What I am wondering is what can I do with it now? I was expecting it to have an On/Off condition that I could query in a program. But it only seems to have Responding=True/False.
  4. Well , I think I found one problem, I was setting the status of the button within the scene rather than the scene itself.
  5. @Goose66 I thought I had this all working but I am still having some problems. I am trying to troubleshoot. Below is my program "Entry All Off" is a scene with only the Entry D button in it as a responder. If 'Entry Light 2' Status is not Off Or 'Entry Light 1' Status is not Off Or 'Kitchen 2' Status is not Off Or 'Kitchen 1' Status is not Off Or 'Master Hall 1' Status is not Off Or 'Master Hall 2' Status is not Off Or 'Living Room Lamp' Status is not Off Or 'Master Dresser Lamp' Status is not Off Or 'Kitchen Cabinet' Status is not Off Or 'Office Lamp' Status is not Off Then In 'Entry All Off' Set 'EntryD' To On Else In 'Entry All Off' Set 'EntryD' To Off The program status says the if condition is evaluating to false ( meaning all lights are off) However the status of Entry D is still "on" I'm expecting when the program runs that the state of EntryD be off, am I missing something?
  6. Got it working. I discovered I had a “room” with the same name in Alexa. As soon as I deleted that the scene started working
  7. the second one works, 1st does not.
  8. Hello, setting up a new ISY with Alexa, I can control devices exposed by the portal with no issues. If I expose a scene and try and control it I get a message that the hub the device is connected to is not responding. Any ideas?
  9. Thanks a lot this seems to work, but one thing I don't quite get is what causes the program to execute? I never assigned it to a button. Is it just constantly evaluated when there is a state change on one of the devices in the If condition?
  10. @Goose66 I am trying to replicate your program, How do I enter Set 'Backyard Keypad Button B' On into the program editor? I found "your devices" "Set". 'Button D' In the next column I see backlight, Query, or write changes. I don't see an option to change a button state.
  11. It tells me that the keypad link button is already a controller, let me clarify, I actually have more than one scene I wish to control with the single button. Kitchen scene (virtual 3way) 1 Switchlink is a responder (switch1) 1 switch link is a controller (switch2) Dining scene (virtual 3way) 1 Switchlink is a responder (switch3) 1 switch link is a controller (switch3) Everything scene 1 Switchlink is a ? (switch1) 1 switch link is a ? (switch2) 1 Switchlink is a ? (switch1) 1 switch link is a ? (switch2) keypad link button is a ? (ButtonA)
  12. Hi all I have a few switches in the house controlled by Insteon switches. I want to link them to a scene I am calling "everything". Creating the scene is easy enough but what's the best way to link it to the Keypadlinc. If I connect it to button A the state of the button doesn't change when one of the switches is on. This results in me having to press the button twice to get the scene to turn off. I ended up switching the button to only send "off" command which is better but it would be nice to be able to turn everything on using the same switch. In this scenario I have a scene called Kitchen scene (virtual 3way) 1 Switchlink is a responder (switch1) 1 switch link is a controller (switch2) Everything scene 1 Switchlink is a ? (switch1) 1 switch link is a ? (switch2) keypad link button is a ? (ButtonA)
