robfitz
  1. Just an FYI, spent some time on the phone with Insteon and the SmartHome folks. Turns ot there is no way to have a KPL Secondary Button control the local load regardless of the firmware version. If this is in deed correct (and we tried it with the 2C, 2D and most current firmware) you should consider removing this capability from your software.
  2. Many thanks to all!!
  3. So are you saying that I need to have a KPL firmware version that is greater than hex 2D or 45 decimal or .45 in the ISY admin console? Where can I get the secret decoder ring that conmverts the admin console firmware values (e.g. .29) to the INSTEON values (e.g.1.4)? Is the firmware version the same reason for the inability of the 2 sets (KPL1 and KPL3) of buttons to sync properly with one another? Many thanks
  4. Still figuring out how Insteon labels their devices, but there's a sticker with V1.4 on the front lower tab of the device. On the reply you note 2D and above. I do not seem to find any of my KPL devices with alpha characters, so I'm not sure if I'm looking at the proper label for firmware or not. When I look at the device via the ISY Admin Panel it shows v.29 on the top line of the work area. Any suggestions on which is the appropriate firmware version source? Many thanks!
  5. It was late;-) It should have read... Scene Dim has KPL1 button 3 and KPL3 button 3 as controllers. It should have read...Buttons 2 and 3 are set up as Mutually Exclusive on both KPL1 and KPL3
  6. Just getting started with ISY99 setup and have run into a couple of issues that need some clarification. ISY has 2.7.7 loaded. Setup is 3 sets of lights controlled by three different 6 button KPLs. We'll call them KPL1, KPL2, KPL3. There are two goals for the setup. To have button 2 on KPL1 and button 2 on KPL3 do a full on all three loads and to have button 3 on KPL1 and button 2 on KPL3 do a 50% dim on all three loads. Scene Full has KPL1 button 2 and KPL3 button 2 as controllers and load KPK1, KPL2 and KPL3 as responders. Set at 100%. Scene Dim has KPL3 button 3 and KPL3 button 3 as controllers and load KPK1, KPL2 and KPL3 as responders. Set at 50%. Buttons 2 and 3 are set up as Mutually Exclusive on KPL1 and KPL2. Problem 1: The KPL from which you are controlling does not seem to dim the load of that device, only the other two loads. On/off works fine. Problem 2: The mutually exclusive only seems to work on the KPL where you are pressing the buttons. The other KPL do not seem to track the feedback status on buttons 2 and 3 of the device you are controlling from. The control-from location works OK, but the oposing KPL feedback stays high until you go to the oposing device and manully cycle the buttons. Have tried a couple of rebuilds of the scenes and resets-rebuilds of the mutually exclusive setups, but same results. Help please. And Many Thanks!
