tummalarb
  1. tummalarb replied to tummalarb's topic in ISY994
    Thank you. I did refer to these articles before asking. For some reason it did not work. I think I missed to do the 'copy attributes' part. It workes this time. Thanks for the great support.
  2. tummalarb posted a topic in ISY994
    Hello, Today I installed two SwitchLinc dimmers in a 3-way circuit. I added both of them to ISY device list. I did not link them using Smarthome's method. How do I link them using ISY? I searched the forum and wiki and found that I can link them by 'adding them to a scene'. I tried doing this and they are not linked even after adding them to a scene! Should I link the two switches using Smarthome's method? Please advice. Thank you. Raj ISY Pro 2.7.15
  3. Sure will. Thank you.
  4. I encountered the same issue yesterday with 2.7.11 alpha. I tried to turn on a lamplinc and due to Insteon communication issue, ISY is unable to turn on the lamplinc and threw an error. Since then I get 'System Busy'. I closed the console and tried opening it again in two different PCs (totally tried from three systems, one of them is Mac). Finally I gave up and unplugged ISY and plugged it back. Can any expert comment on this? This is a serious issue for me, as sometimes I will be controlling ISY remotely when I am not home and it would not be possible to power cycle the device.
  5. I just started using ISY Pro (2.7.10) from past one day. I did search the forums and did not find exact answer. I want to run a program exactly at Sunrise and Sunset times. Any help is appreciated. Thanks in advance.
