blu53e
  1. Thanks for your help. That's the path I pursued.
  2. Thanks. I just recently installed my new ISY and was moving my network from another product I had. I followed the instructions to link my RemoteLinc to the ISY and created 6 quick programs but as stated, can't get 'all on/all off/bright/dim' to work or figure it out. After reading your posts, the solution appears to link the RemoteLinc directly to the device vs. using ISY. This is how I had it originally with the other product as they didn't support RemoteLinc. Although I understand using ISY to control my devices via RemoteLinc is adding a middle man, it would offer a bit of flexiblity to what I want to do as well as saving my configuration, etc vs having to run to a bunch of devices and reprogram my RemoteLinc in the future - should it die, loose its memory, etc.
  3. I was able to successfully program my 6 primary buttons on the RemoteLinc with the ISY. However - how do I program or make the All On, All Off, Dim and Bright buttons work? Thank-you in advance for your spport. Gary.
