KNicklow
  1. Thanks for the suggestion on the upgrade. I'll see if I can find documentation on how to do that. I assume you're referring to the "Z-Wave" version in the administrative console. If so, it's 6.82.01. I made some progress in getting the Wallmote interactable, largely ignorance on my part for the programming. Notes in one of my responses below. Thanks for the screenshots! These made a huge difference. I have been able to get the "Scene Button 1" on the Quad to flip a SmartSwitch7 on, but it's running both the "Then" and the "Else". Based on my experience with other languages I would expect it to only run the "Then" when the "If" conditions are true. All I'm trying to do is toggle the switch on and off with a button press. Any suggestions on what I might be doing wrong?
  2. Thanks for the reply. Very useful information here. I looked at my unit and it has a blue LED on the front, but not the rear. So based on that I am assuming it is a 500 series device. I did just purchase it however and am wondering if I should have the PolisyPro instead? I did not see any data on the listing on Amazon from UD which indicated that so perhaps I missed something there. The Aeotec device I'm playing with is physically sitting next to the ISY994i. I don't think range is the issue. This is more of that the devices it discovered don't seem to be interactable. It's almost as if it doesn't understand there are buttons. Additionally, having played with the Programs, it isn't obvious to me how I'm supposed to code for them. I assumed they would exist in the "If" logic, but really unsure about that. The documentation (PDF) I found was confusing to navigate.
  3. Hello! New user just learning the Universal Devices ecosystem. I have an ISY994i running the following... ISY Model: ISY 994i 1024 Platform: ISY-C-994 Version: 5.3.0 Build Timestamp: 2020-10-01-14:44:54 I purchased an AeoTec WallMote Quad (ZW130-A) with the intention of using it to trigger other things through the UD automation platform. However, upon adding the device, it doesn't seem to do much of anything. The UD interface just changed so naturally I'm struggling with that, but I haven't found anyway to use this. Any suggestions? I looked through documentation but I couldn't find anything useful. Thanks in advance and apologies for my ignorance!
