ACastiglione
  1. My node server is now connected. Left P3x running all night and it was connected in the morning. HOWEVER, my IoX does not show Kasa in the list of Node Servers (only show Hue) but it does show it in the configure drop down under node servers as shown in the image. Also, it is listed as a device ("Kasa Controller") on my IoX Network list of devices as shown in the second image. As you can see, its just the controller. I only have one Kasa device (Outdoor dimmer KP405) but it is not listed under the Kasa Controller. Any suggestions?
  2. I also voted, but didn't run an errand; instead went to meet a couple colleagues for a few brews and apparently missed the train. I followed all the steps Michel advised: 1. Upgrade Packages 2. Install Dev Packages 3. <Restart IoX> 4. Reinstall Kasa (you must reinstall) 5. Ignore timeout ... compilation of kasa module takes about 5 minutes on eisy and 10 minutes on polisy I also did a Restart as indicated by Trion and still not on the train. I downloaded log package and attached here. Also included a screen shot of the log. I'm sure I'm missing something. I have Polisy and running Version 5.7.0 and Polyglot 3x Version 3.1.0. Any additional suggestions? Kasa_11-7-2023_103609-PM.zip
  3. I'm having same issue (i.e., No Module named 'Kasa'. I included the downloaded log report. Kasa_11-6-2023_63726-PM.zip
  4. Thank you for the update Michel.
  5. Does anyone know if the ZMatter module (no USB attachment) that has a ZWave antenna and Zigbee antenna and plugs into the Polisy board by opening the box will have the Zigbee functionality when the update is released? I bought the Zmatter module and installed it and have added my ZWave devices and is working great. However, there is no ability to add Zigbee devices. Am I missing something?
  6. After reading this forum all day and testing my system on what I read around this particular lock, I repositioned my ISY and was able to obtain accurate status (i.e., Locked and Unlocked). I was not able to get the "Options" button to appear so I started playing around with configuration parameters based upon this lock's z-wave codes. I will update if I'm successful. I stayed with the current version and did not downgrade.
  7. I do have other wave devices near the lock (2 plugs within 5 feet) and the lock is about 30 feet from the ISY994
  8. I have been reading other related topics on my particular Schlage lock and it appears that some of the users have reported that versions 5.2 and above report problems with the Schlage locks. Anything under 5.2 provides full control of the locks with options button present. My lock UI in ISY994 looks like this:
  9. I was think possibly the opposite in that the firmware is up to date but is the Beta Version. I was thinking about doing a factory reset and manually adding all my devices and programs back rather than restore from a backup to see if that solves the problem. I will wait to see what https://forum.universal-devices.com/profile/4175-lilyoyo1/ thinks. Appreciate your help.
  10. Thank you MrBill and lilyoyo1 for responding so fast. This is my very first request for help on the UD forum and I'm pretty damn impressed on the folks out here willing to help. FIRMWARE: Insteon_UD994 v.5.3.4 (2021-07-07-14:45:02) UI: Insteon_UD994 v.5.3.4 (2021-07-07-14:45:02) LOCK: BE469ZP CEN 716
  11. I am brand new to this forum and this is my first post. I have been using the ISY994 for quite a while but have only touched the surface of its capabilities. With that said, I cannot seem to stumble on a solution to the problem I'm having. I just installed a Schlage Connect Deadbolt lock and my ISY found it and I can issue basic lock and unlock commands. I can also set a password. However, I cannot do any programming because the status of my lock always says "Unknown". Is there something I am missing when including the lock into my network? I have excluded it and then included it and the status remains "Unknown" but the lock and unlock commands work. Any help would be greatly appreciated. Thank you. Tony
