tbuchber
  1. I have UD Mobile, version 1.1.51, on iOS 17.4 Beta. I have Location sharing for UD Mobile set to "Always" and "Precise Location" is on. Whenever I create or edit an existing geofence in UD Mobile, it appears that the minimum radius is "200" (meters). If I set the radius to "100", touch Save, and then check the radius, it is set to 200. Based on https://wiki.universal-devices.com/index.php?title=UD_Mobile#Geofencing, the minimum radius is 100 meters. However, that is not the behavior I am seeing.
  2. I did at least five Factory Resets on the problematic 2477S. I did not do a Factory Reset once I took it out of the wall. If you think that somehow that there is value on that, now that the switch is out of the wall, I can do that.
  3. Thanks for the information and feedback. I had one other 2477S, which happened to be new. I connected the new 2477S to a test "harness"; the switch is not beeping on Insteon traffic. Note however that I have not done a Factory Reset. I took the problematic 2477S (the one beeping on all Insteon traffic) apart. I took the guts out of the clear case; the only thing remaining in the case was the piezo "speaker". By taking the guts out of the case, that provided separation between the piezo "speaker" and the circuit board. In my case, it is definitely the piezo "speaker" that is making the noise.
  4. Thanks for the info. Here is what I tried next. 1. Removed the power from my ISY. 2. Unplugged the Insteon PLM Serial Modem Interface from the wall outlet. 3. Did a factory reset on the 2477S. 4. Tested and still beeping on Insteon traffic. I do have one other 2477S (a new one) that I can swap out with. The 2477S that is currently installed and beeping, I believe has been exhibiting this behavior (beeping on Insteon traffic) since I installed it. The beeping mainly bugs my wife. This 2477S is in our master bathroom, in the toilet area for the exhaust fan.
  5. Firmware: Insteon_UD994 v.5.3.4 (2021-07-07-14:46:02) UI: Insteon_UD994 v.5.3.4 (2021-07-07-14:46:02) I did the following: 1. In the Admin Console, I removed the 2477S from folder it was in. 2. I closed the Admin Console. 3. I air-gaped the 2477S for about 15 seconds. 4. I pushed in the set button and held it in until a few seconds after the long beep ended. The 2477S double-beeped and turned on the load. 5. I turned on the dimmer switch that is right next to it and the 2477S emitted two (?) short beeps. Note that at this point, I have not restored the 2477S in the Admin Console. And I know it is the 2477S that is beeping because if I air-gap it, then no beeping occurs when I interact with other Insteon devices. 6. I opened the Admin Console. 7. I used Restore Device. 8. I turned on the dimmer switch that is right next to it, the 2477S emits two (?) short beeps.
  6. I have one and only one Insteon 2477S installed. It beeps when it senses Insteon traffic. In the ISY 994 Admin Console , it said (2477S) Dual Band SwitchLinc On/Off Switch v.45. I did link it to the ISY. I can turn it on and off. However, I cannot find a way to turn off the beeping. I have done a factory reset (using the air gap, waiiting 5-10 seconds, pushing in and holding, I get the two confirmation beeps) and that did not help. The Admin Console provides settings for On, Beep, and Backlight. For actions I have On, Off, Fast Off, Fast On, Query, Beep, and Write Changes. Thoughts?
