DGaylord
Everything posted by DGaylord
  1. I've done just some limited testing with 4.0.4; but now I can programatically turn zones and programs on again. Cautiously optimistic that everything is 100% functional now.
  2. My most important use of this NS is to have a couple of zones triggered to run their schedule based upon logic using the Ecowitt NS which uses soil moisture sensors to trigger watering only when needed. Today there was a need for watering and the Ecowitt NS called for it but the Rachio NS threw an error, 'RachioController' object has no attribute 'r_api', when ISY sent the Start command to the zone. The same behavior can be duplicated using the Admin Console to manually enable any of the zones. Please see the last two lines of the log file for the error.debug 4.0.3 Write Error.logdebug 4.0.3 Write Error.logdebug 4.0.3 Write Error.logdebug 4.0.3 Write Error.log
  3. It looks like everything is working now. All of the Zones and Schedules came in and all are updating correctly. I'll keep an eye on it for the next couple of days but from what I can tell now it looks like you got it. Thanks for the perseverance!
  4. For whatever it's worth, as I converted from PG2 to PG3 version I noticed that the recommended default Port had changed from the previous version. I believe PG2 was recommended to be 4001 and PG3 is recommended for 3001. I did reconfigure my port forwarding to 3001. This probably is of no help; but figured I better mention it.
  5. 4.0.2 installed. Still no zones or schedules identified. Went so far as to uninstall/reinstall NS and rebooted everything. Log attached. debug 4.0.2.log
  6. I updated to 4.0.1. Restarted NS. Restarted PG3. Restarted ISY. Now I have two nodes in Admin console: Rachio Bridge and Autumn Bliss (my controller name) no zones or schedules in either one. Now log file (attached) shows that the zones are detected but they are still not appearing in the Admin Console. debug 4.0.1.log
  7. Trying to convert from PG2 to PG3 version. PG2 version was working correctly. I uninstalled it and installed the PG3 version. I added API key and host name. Node server and controller get added to ISY (on Polisy) but no device nodes are identified. API key seems to be accepted. Port 3001 is forwarded to Polisy. Log attached. Thanks in advance for any ideas. debug.log
