mbeauchemin
Everything posted by mbeauchemin
  1. Following up - IoX v.5.5.3 resolved this issue - my remote has nodes. My repeaters also now show up as nodes after removing and re-pairing. Thank you UDI and this awesome community!
  2. Same issue here but with a Somfy Z-Wave remote (for shades). Worked with the ISY994 and Polisy with ZMatter board prior to migrating to ZMatter firmware. No ask for authentication options either. Running Polisy with ZMatter board and IoX v.5.5.2 migrated to ZMatter firmware. The board has been factory reset and I've started building the ZWave network from scratch. Some devices, such as thermostats and plugs, are pairing just fine. Nodes never show up in the Network view (and I expect 4 nodes per previous experience), but the remote acts like it is paired. I have to un-pair it and re-pair to get the same message. No combination changes the outcome.
  3. Hi bcdavis75, I am running into the same error. Has it happened again since the 7th? What Sonos devices do you have on your account? Are you noticing it happening after / during any specific interaction with a specific speaker?
  4. So I keep restarting the node server and it keeps crashing with the same error. I enabled debug logging on the last cycle and it appears it fails right after communicating regarding my Sonos Roam. Restarting and trying again to see if it is repeating this pattern. 2022-06-27 14:06:11 debug: NS: Volume Change: {"uuid":"RINCON_38420B33FC4601400","previousVolume":53,"newVolume":53,"roomName":"Sonos Roam"} 2022-06-27 14:06:11 debug: NS: UUID: RINCON_38420B33FC4601400 - Room: Sonos Roam - New Volume: 53 2022-06-27 14:06:11 debug: NS: Message Sent: { set: [ { address: 'b33fc46', driver: 'GV0', value: '53', uom: 51 }, [length]: 1 ] } 2022-06-27 14:06:11 debug: POLY: _sendMessage: sending {"set":[{"address":"b33fc46","driver":"GV0","value":"53","uom":51}]} to udi/pg3/ns/status/00:21:b9:02:28:1f_3 2022-06-27 14:06:11 error: NS: uncaughtException REPORT THIS!: TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) ... @simplextech any insights or suggestions for debugging? I'd really like stabilize this NS so I can actually buy it in confidence. Happy to provide the whole debug log for your review. Thank you!
  5. Hello! I recently purchased a Polisy and installed the trial version of ST-Sonos to test it out before purchasing. The node server runs for about a day with no issues and then errors with the following stack trace. Restarting the node server is successful and it works again for about a day until it crashes again in the same manner. 2022-06-07 14:03:20 error: NS: uncaughtException REPORT THIS!: TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:539:35) at /var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 2022-06-07 14:03:20 error: POLY: uncaughtException: Cannot read properties of undefined (reading 'members') TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:539:35) at /var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) 2022-06-07 14:03:20 error: NS: uncaughtException: Cannot read properties of undefined (reading 'members') TypeError: Cannot read properties of undefined (reading 'members') at Player.recalculateGroupVolume (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/prototypes/Player/recalculateGroupVolume.js:4:32) at NotificationListener.notificationHandler (/var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/models/Player.js:370:25) at NotificationListener.emit (node:events:539:35) at /var/polyglot/pg3/ns/00:21:b9:02:28:1f_3/node_modules/sonos-discovery/lib/NotificationListener.js:125:17 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) Let me know if there is anything else necessary to further troubleshoot. I would like to get this functional so I can test before buying. Thank you!
