mitch236
  1. Thanks I tried copy to clipboard but it only shows text: Gate KPL-A - [ID 0002][Parent 006C] If 'Indoor / Foyer / KPL Foyer Right / Right Front Door KPL.A Gate' is switched Off Then Set 'Outdoor / Gate / Gate Relay' On Wait 1 second Set 'Outdoor / Gate / Gate Relay' Off Else - No Actions - (To add one, press 'Action') But is this what you meant for me to program if I always want the backlight off?
  2. I have a relay that controls my gate. I use a KPL button to open the gate so I've made a program to do that. The problem is I can't figure out how to turn the KPL button off after it's activated. Can someone help me please?
  3. Ok, then maybe I don't even need an ISY. Is the Alfred lock cloud based?
  4. Long time UD user here. I am buying a property (house) that we intend to use occasionally and I'd like to use a 994 to automate and allow remote control and was wondering about the latest advances in devices. I'd like a front door lock that I can remotely control. If I could remotely change the entry code that would be even better. Also, I'd like to control the thermostat. What's the latest technology in these areas? Money isn't really the object, I want the most reliable products since I'll be in a different state and can't really travel at a moment's notice. TIA!
  5. My car has a feature that automatically engages Homelink within a certain distance to my home. I have a program on my ISY that does multiple things and I currently use my phone to activate this program through Mobilinc but I have to open the phone and open the Mobilinc app then press the program button. I'd like to have the car run this program automatically. BTW, the car is a Tesla and I'm also trying to figure out if I can accomplish the same thing through a node.
  6. This is going to be difficult to describe but here's what I'm hoping to do. My car has a programmable Homelink button (like most new cars) and I can program it to open common garage doors. Instead if it opening a garage door though, I want it to trigger a program within the ISY. IOW, when I arrive home and activate the "garage door opener" in my car, instead of a garage door responding, a program within the ISY runs. Is this possible and if so, what do I need? Thanks!!
  7. I cannot figure out how to add "Query All" back to the Then statement. What type of command is Query All listed under?
  8. After I upgraded from 4.8.0, I had to "Save Changes" in my programs and the Query All command is missing the "Then" instructions. Should I fix the Query All?
  9. mitch236 posted a topic in ISY994
    I've been using a SwitchLinc 220V - INSTEON Remote Control 220V Switch Kit in Weatherproof Enclosure for a few years to control my pool pump but it isn't responsive anymore. When I tried to purchase a replacement, I couldn't find any high voltage product to use with my system. Is there anything available to control my pool pump through ISY?
  10. I'd like to add video to my home security system but want it to integrate with ISY. It would need to be wifi and store video both locally and in the cloud on a looping basis. What are my options? I know this is an open question but I don't want to spend an enormous amount of money just to find out it really isn't my best option. Thanks for your input.
  11. Thanks! I deleted the old location and had it search me out and magically it's back!!!
  12. I haven't been active in a while but all of my HVAC thermostats are conditional based on outside temperature and my weather module is saying 0 degrees even though it's about 80!!
  13. I figured out the z wave issue as well. Turns out you have to remove the device before you can add it. Thanks! I'm back up and running perfectly!
  14. I do have a separate issue now. It seems my Z-wave network is no longer working. How would I rebuild it? It's only 3 devices so it should be very easy but when I look for existing devices, none are found and when I try to add devices, it won't "see" them.
  15. Thanks, I figured it out. As Brian stated, I had to update the UUID with Mobilinc but I also had to re-purchase the portal module. Everything is perfect now. I did notice one weird thing though, when I restored my ISY programming, I got an error message about not being able to complete it (I don't remember the exact error) but it seems to work just fine.
