JAboud
  1. JAboud replied to JAboud's topic in ISY994
    Just tried to change the status of the party lights and it worked, despite the error that the console couldn't communicate with it.
  2. JAboud replied to JAboud's topic in ISY994
    Sorry for the ghosting, been under the weather. So here's some new updates. Of the lights in my program: Driveway, upstairs lamp, and party lights, only the Driveway light is responding appropriately. If the party lights turn on, they won't turn off, but they rarely turn on. @MrBill - I've checked and the folder option. I've recreated it, even though it was already set that way. Today, I received an error saying that the Admin console couldn't communicate with the part lights. Given it's age, 9 years, I should probably replace it. My hesitance is that I don't want to throw more money into the system only to have thee same problems. @MrBill- I'll give the breaker test a shot tonight and let you know. Thanks to all for their help!
  3. JAboud replied to JAboud's topic in ISY994
    @Geddy I'm not relaying the problem correctly. Before the upgrade - the programs would run but not always successful. One day the party lights would come on but the driveway and porch lights would not. The next day, none would work. The next only the driveway light would come on. Same program different results. After the upgrade I had to recreate the programs from my documentation. Today for example, the party lights came on but didn't turn off. The 2nd floor lamp, didn't turn on. Today, however, the thermostat did set correctly. I apologize if I'm not making any sense. The situation seems random and I can' figure out how to adequately portray the problem. I hope this help clarify things.
  4. JAboud replied to JAboud's topic in ISY994
    Running "Run Then" worked. But running the if didn't. The first time, I got an error saying that couldn't communicate with party lights. Second time, no error, just didn't work. I setup a simple third program that turns the upstairs lamp of at 10pm. Running the IF didn't work but running "Run Then" did.
  5. JAboud replied to JAboud's topic in ISY994
    The thermostat is an Insteon stat. The overall problem is that none of the programs are working. Lights don't go on/off when the program runs. This has been a problem for a while - prior to the 5.x upgrade. Before the upgrade, when the Night Shutdown would run, some of the lights responded some didn't. And that varied from day to day. After the upgrade, none of the lights are controlled.
  6. JAboud replied to JAboud's topic in ISY994
    @Geddy - Got it. Thanks.
  7. JAboud replied to JAboud's topic in ISY994
    @Geddy, Thanks for the information. I'll upgrade tonight. @ SimplyPizza here's the thermostat program
  8. JAboud replied to JAboud's topic in ISY994
    SlimplyPizza - OK I feel stupid. Unfortunately, that doesn't address the thermostat issue.
  9. JAboud replied to JAboud's topic in ISY994
    lilyoyo1, Thanks for the reply. I check the items you suggested. The images are attached. One thing you did mention triggered my memory. I think I do have the pro version. Does that make a difference.
  10. JAboud posted a topic in ISY994
    I upgraded my 994i to v 5.0.16 in January. Programs immediately indicated "out of memory" error. So, I reset my 994i and recreated two of the programs and ran them manually. I tested each of the insteon light controllers manually and could toggle the lights through the admin console. However, when left to the schedule, none of the programs are working. The Summary page indicates that the programs ran, but the lights didn't turn on/off at the scheduled times. I went back and tested them individually, through the admin console, and they worked. The Thermostate program doesn't work either. This has been going on for at least 6 months before the upgrade. Under the previous version, scheduled programs would randomly work or not. I was hoping that the upgrade would resolve that problem. Any help you could offer would be appreciated.
