AZCRUM
Everything posted by AZCRUM
  1. Yes, I have now resolved that issue. I can access the ISY from browser and UD mobile local connection. I believe I need to resolve this CA cert issue.
  2. Small tweak to the IP address and the error now reads: ErrorDomain=NSURLErrorDomainCode=-1202 "The Certificate for this server is invalid. You might be connecting to a server that is pretending to be "xxx.xx.xxx.xx" which could put your confidential information at risk" the xx.xx.... is my correct iP address. So if I can be pointed to a step by step on how to convince UD Mobile that I'm fine with my server, that would be fantastic.
  3. After pressing "Test remote connection" i get the "looking for isy" for quite a long time followed by: "Error Domain=NSURLErrorDomainCode=-1001 "The request timed out." userinfo={_KCFStreamErrorCodeKey=60, NSUnderlyingError=0x280c00000 {Error Domain-KCFErrorDomainCFNetwork Code=-1001 "(null)" UserInfo={_NSURLErrorNPathKey=satisfied (path is satisfied), interface:...
  4. Yes, I do see your point. specially the super easy part. My mind set wasn't to go the super easy route, and so am getting bugged down trying to figure this out. Definitely not going to give up, not just yet. Thanks,
  5. A ha ! ... Do I need to purchase a CA Cert??? I think that is the step I'm missing. How does one purchase a CA cert? I did notice there were a number Ca cert set up when looking in the network setting. And then there's the server certs and the client certs. At the end of the day, I think getting past this stuff is the key... Thanks,
  6. Good morning! I do not have a portal account. I would like to setup UD Mobile for direct connection remotely. thanks
  7. Good morning, and thank you for responding to my post. Yes, I’ve tried all steps. At this point, I think my lack of intuition when it comes to CA certificates is the problem. Although, I can’t say for sure that I have the correct format for my zip addresses (other apps I’ve setup just ask for the DDNS address) ISY Firmware ver: 5.3.4 Device: ISY994i -IR-PRO connected to: Powerlinc 2413S integration: Insteon & Elk Thank!
  8. I've gone through every instruction available on how to setup the UD mobile for Remote connection. Just can't get it to connection Remotely (Not local Connection). Hoping someone can help. Thanks
